Author Topic: 1968 Camaro  (Read 6561 times)
wisemanz28
1968 Camaro
« on: February 15, 2020, 10:27:39 PM »
If a 68 Camaro came with a standard interior  would it be possible if the seats would have  white stripes on them? Also how many M22 transmissions did they put in 68 Camaros?
Re: 1968 Camaro
« Reply #1 on: February 15, 2020, 10:35:29 PM »
Quote
What do you mean by "white stripes"?
Quote
1,277
wisemanz28
Re: 1968 Camaro
« Reply #2 on: February 15, 2020, 10:57:00 PM »
I'm going to look at a 68 Z28  that has been sitting since 1978 tomorrow  and the seller thought the seats had " a white strip that outlines the seats" on them . How many M22,s made it into 68 Z28,s ?
Re: 1968 Camaro
« Reply #3 on: February 15, 2020, 11:07:28 PM »
Quote
In that case, no, not from the factory.
In 1968, the M22 was available for the Z28, the L78 and the L89, but I don't have a breakdown to the number that went into each.
Fred Mertz
Re: 1968 Camaro
« Reply #4 on: February 16, 2020, 01:20:22 AM »
I think some interiors in '67 had white stripes.
Re: 1968 Camaro
« Reply #5 on: February 16, 2020, 03:08:19 AM »
Yes, 67 deluxe seats had accent stripes (white or black depending on the interior color), but not 68.
Re: 1968 Camaro
« Reply #6 on: February 16, 2020, 09:06:23 PM »
Hard to prove a 68 trans is a M22 originally. Everyone says that they got one (most aren't) and the guts could have been swapped out.
Re: 1968 Camaro
« Reply #7 on: February 17, 2020, 04:10:16 PM »
Agree Kurt but what about drain at bottom which would assume might be difficult to replicate, and didn’t the m22 have a C stamp on the case.
Re: 1968 Camaro
« Reply #8 on: February 17, 2020, 04:48:10 PM »
Quote
Easy to add during a rebuild. I've seen several fake M22's over the years with that drain plug added! And the C wasn't used during the 1968 model year. It didn't show up until October 21st, 1968, early in the 1969 model year.
Re: 1968 Camaro
« Reply #9 on: February 17, 2020, 07:24:13 PM »
Send me an email.  There are some things we can examine to help determine an original M22.
BRG Z28
Re: 1968 Camaro
« Reply #10 on: February 17, 2020, 09:55:52 PM »
My 68 is an original M22 Z28. A M22 will have two “Lisle” drain plugs, M22 trans number tag and no grooves on the input shaft. As was noted earlier, 1968 did not have a “C” in date code.
