Author Topic: 1968 Camaro Distributor and Vacuum Advance Pod  (Read 4124 times)
gwp4
« on: December 10, 2019, 06:17:20 AM »
Hi Folks -
I've got a 1968 Camaro 327/210 SB no ac 3spd and am looking for an original AC Delco 1111440 distributor and the factory correct AC Delco Vacuum Advance Pod.  Unfortunately, I can't locate the GM part number on the pod or the correct page in the FAIM where it might be located.  Any Camaro experts have the info?  Many thanks.  gwp4
Re: 1968 Camaro Distributor and Vacuum Advance Pod
« Reply #1 on: December 10, 2019, 06:22:58 AM »
It won't be in the AIM because it came with the distributor.
part # 1115355
Personally, I wouldn't sweat finding an original - more important to get one that works.
« Reply #2 on: December 10, 2019, 02:01:49 PM »
I completely agree with Kurt. The original vacuum advance units were horrible for performance. Great for smog control, but horrible for performance. Read THIS a list of for part numbers on a vacuum advance that works MUCH better in these engines.
However, if you're restoring the car for show and will never drive it, then get the 355 can.
« Reply #3 on: December 10, 2019, 07:18:04 PM »
I might have a distributor. If I do will send you a pm. What date do you need?
gwp4
« Reply #4 on: February 26, 2020, 05:24:33 AM »
Hi -
I'm looking for a date code in the March/April/May 1968 time frame.  I hope you can help me out.  Many thanks.
gwp4
« Reply #5 on: February 26, 2020, 03:55:15 PM »
I didn’t find any 327/210 hp distributors, but I did find several 327/275 hp distributors.
