Author Topic: Air Cleaner stud length  (Read 7349 times)
uscrichter
« on: April 10, 2019, 05:14:48 PM »
Does anyone know the correct stud length for a 396 with Q-Jet carb open air cleaner(L-34)? I had ordered one through HBC, the one they reference as correct and it was way to long, any one know where to find the correct one? I'm at the 11th hour of restoring my '68 .
Re: Air Cleaner stud length
« Reply #1 on: April 10, 2019, 05:48:51 PM »
  Here is one from a '67 L35 Q/jet and still with original finish. This should be the same for 68?
Looks like a tad under 3 1/16".
uscrichter
« Reply #2 on: April 10, 2019, 06:04:01 PM »
Thanks Mike!, Is the wing nut phosphate coated as well?
Curt
« Reply #3 on: April 10, 2019, 06:14:17 PM »
Curt
Yes...but my lids are black. For 68 the lids were chrome so the wingnut is likely chrome too (?).
uscrichter
« Reply #4 on: April 11, 2019, 06:00:49 PM »
Good point! Thanks for the help Mike.
uscrichter
« Reply #5 on: May 14, 2019, 10:58:58 PM »
Does anyone know where to buy one of these 3" air cleaner studs? I have searched and not been successful in finding one and its' one of those finishing touches I need. Thanks
« Reply #6 on: May 15, 2019, 12:35:06 AM »
uscrichter
« Reply #7 on: May 16, 2019, 05:23:57 PM »
Thanks for the help, but when I called Paragon to find out the length they said it is 3.5" long, so I am still on the hunt , I'm not sure why the repros are longer than the OE versions or why I cannot seem to find the correct one.
Camarocards
« Reply #8 on: May 16, 2019, 11:28:01 PM »
AMK offers several air cleaner studs. They do have a 1/4-20 x 3” stud (B-10030). They also offer a 1/4-20 x 3.5” stud which they list as equivalent to p/n 3921975 (agrees to what is called out in the AIM). AMK products are typically very accurate and I would go out on a limb and say the HBC one is wrong.
https://www.amkproducts.com/wp-content/uploads/Catalog_BulkFastener/BULK_120-127.pdf
Downside is they have a $30 minimum order policy.
Bob
Bob
'68 SS L35 01D
uscrichter
« Reply #9 on: May 20, 2019, 07:52:11 PM »
Thanks Bob! I have bought AMK bolts and didn't know they had these .
« Reply #10 on: May 20, 2019, 08:25:32 PM »
I don't see the little 'step' in the AMK stud. But, being it isn't visible when mounted it probably may not matter.
Camarocards
« Reply #11 on: May 20, 2019, 10:02:37 PM »
Mike,
Yes, I noticed that as well. I’ve yet to find anyone that sells the stud that has that detail. But You’re right, it’ll never be seen anyway.
Bob
Bob
'68 SS L35 01D
Bigfish45
« Reply #12 on: August 07, 2019, 01:06:03 AM »
I've always made my own out of 1/4 X 20 threaded rod to whatever length I needed. Might not be "technically correct" but I can make one for about fifty cent. Not to mention, you can't see the stud with breather assembly on the carb anyway.
