Author Topic: Original ignition coils  (Read 67115 times)
« on: August 02, 2018, 03:17:45 AM »
Lots of questions on what ignition coil is original. An often changed part and the original configurations are poorly documented in manuals.
One thing to know - the coil and bracket were shipped as an assembly to the assembly plant. What is a bit different is the last three digits of the assembly part # were the numbers embossed into the coil. The various brackets changed the angle /location of the coil for clearance.
Also the BR embossed on the coil went to B-R for 69 (the drawing change was dated 9/12/68)
What I know from the AIMs and broadcast sheets and car data.
67-69 L6: 1115208
67 V8: 1115267 used on many applications including LF7(base 327), L35, and L78.
Appears 270 and another coil (290??) were used on SS350 and L30 cars. It looks like the wiring harness and ignition resistance wire changed and so it may be an early vs late thing.
68 V8: 1115293 - all engines
69 V8: 1115293 - used on all engines except below
           1115298 - Z28
           1115270 - Z28 and L48 with cowl hood  (but not BB with cowl hood)
           1115210 - ZL1 TI units
After pulling this together, the biggest question is the coil for the 67 L30 and L48 cars.
And the differences between the brackets.
« Last Edit: August 06, 2018, 04:24:43 AM by KurtS »
Northernforce
Re: Original ignition coils
« Reply #1 on: August 06, 2018, 01:32:02 AM »
Great info!!!!Thanks Kurt!
Keep on Cruising!!!!
Dave
« Reply #2 on: August 06, 2018, 01:58:48 AM »
Does the BR or B-R mean something? or indicate something??
« Reply #3 on: August 06, 2018, 02:39:51 AM »
I believe most (maybe all?) were made by Delco-Remy.
You may see BR or B-R and 12V or 12-V on them, depending on the year.
I am not aware of what the BR or B-R stands for.
« Reply #4 on: August 06, 2018, 04:23:53 AM »
BR is believed to be for Ballast Resistor.
« Reply #5 on: August 14, 2018, 01:19:11 PM »
Kurt
so the BR would indicate that the resistance wire or a ballast resistor must be used?
« Reply #6 on: August 14, 2018, 02:27:46 PM »
 I had this informative chart on coil usage bookmarked:
http://chevellestuff.net/qd/coil_numbers.htm
Buzz67
« Reply #7 on: September 19, 2018, 09:23:14 AM »
What finish black is correct? Should they be 30/60 or gloss?
Buzz
'67 RS/SS L35, M40, Red/Red Coupe, NOR
Original Drivetrain w/3.73 posi
Original Rally Wheels, Manual Disc, Steering
3rd Owner
« Reply #8 on: September 19, 2018, 01:00:57 PM »
 I am certain they are full gloss (not sure what the % was considered back then) based on the originals I have.
stovebolt
  • 1968 L6 Sport Coupe
« Reply #9 on: September 19, 2018, 01:22:29 PM »
These photos are of my original 208 coil. Looks like semi-gloss. May have been shinier when new. Hope this helps. Joe.
luv2sixty9
« Reply #10 on: June 08, 2019, 05:18:51 PM »
298 for a 68 Z28
1967 Z/28 Butternut Yellow
1969 Z/28 Rally Green
1969 RS Z/28 Lemans Blue
1969 RS Z/28 Olympic Gold
1969 RS SS Pace Car
2010 Aqua Blue 2SS RS
« Reply #11 on: June 11, 2019, 06:06:24 AM »
298 for a 68 Z28
For a 68, that's in conflict with other cars have. They used 293's.
jdv69z
  • 69 RS Z/28 52E
« Reply #12 on: June 11, 2019, 03:17:07 PM »
So did the 69 Z28 use a different coil, or is it the coil/bracket that makes it a different part no.?
Jimmy V.
luv2sixty9
« Reply #13 on: June 18, 2019, 11:09:35 PM »
"For a 68, that's in conflict with other cars have. They used 293's"
My survivor 68 Z28 has a 298 coil, which is also used on 69 Z28 with the flat hood.
1969 RS SS Pace Car
« Reply #14 on: June 19, 2019, 06:26:28 AM »
The docs are clear, one coil for 68 V8. But Danny's car is a 298. Several others are 293.
I don't have a single Chassis Broadcast sheet for a 68 Z which would tell us something.
Wonder what's on Chick's and Steve's cars.
