After reading all the posts, I was curious to how far off the set of shields I ordered from HBC are from the originals that were installed on my Z.
What I noted:
- Thickness for reproduction shields is exact to the orgiinals, except for the dust shield by the steering column/inner fender with the bracket. That particular shield is about 2X thicker than the others. Fortunately, my original is in excellent shape and re-usable.
- The reproductions are glossy. My originals are mat finish, but not sure if that's because they are nearly 50 yrs old, have road grim, and over-spray paint. I'm wondering if it's possible to tone-down the gloss with some acetone/lacquer thinner or use a satin rubber spray paint?
- The texture isn't that far off, but the reproductions are missing the string strands. I wonder if its possible to lay some string strands on the reproductions and add light coat of some sort of rubberized material or paint to blend them in?
Here's a image comparing the two - I'll note that the texture is a closer match than what appears in the image.
