Author Topic: Radiator for vintage air? Stock or aluminum?  (Read 8963 times)
dalekerr
« on: May 31, 2018, 01:35:57 AM »
I am ordering Vintage Air for my new toy, 67 with 327 upgraded a little. The car is currently running a bit hot now, I know the stock radiator needs cleaned out. Will the stock 21 inch radiator be able to handle the new AC unit? Or should I change it to a 3 core alluminum.
The car  is not 100% original the last owner added rack and pinion steering along with a new modern distrubuter.
I plan to drive the car about 3,000 miles per year.
Dale Kerr
1967 Y 2 350 M20 12 Bolt Vintage Air
03D
Re: Radiator for vintage air? Stock or aluminum?
« Reply #1 on: May 31, 2018, 11:43:08 AM »
A little searching and you could make an educated decision.  Factory required at least a 3 row radiator when A/C was added.  If your stock radiator is 2 row then go ahead and upgrade to aluminum 3 row since originality isn't a concern.  If you are running a stock fan & clutch and are still concerned with overheating then add an electric fan.  But 190-195°F is normal operating range.  Hell newer cars with aluminum engines run even hotter but that is also partially due to emissions and the ability of its sensor monitoring system.
http://www.camaros.org/coolingsystems.shtml#application
dalekerr
« Reply #2 on: May 31, 2018, 10:44:28 PM »
Thanks, so a 190 thermostat and three core radiator and I should be fine?
Dale Kerr
03D
« Reply #3 on: May 31, 2018, 11:40:05 PM »
My radiator guy says aluminum radiators are junk, tubes are too big. I would use a three row brass and copper to keep him happy.
« Reply #4 on: June 01, 2018, 12:53:49 AM »
Age old debate.  They both have their pros and cons.
« Reply #5 on: June 01, 2018, 01:21:04 AM »
I agree.
« Reply #6 on: August 06, 2018, 06:49:55 AM »
Aluminum is not repairable, fwiw.
See http://www.camaros.org/pdf/corv_cooling2.pdf
dalekerr
« Reply #7 on: August 06, 2018, 11:18:32 AM »
Well vintage air is installed and blowing cold. A blessing here in Louisiana, with the temps in the 90’s now. Car runs cool while driving down the road with aluminum 4 core radiator and stock fan and shroud (190). Gets up to about 220 while setting a while, I may need to put on an electric fan.
Thanks for all the help from members of this site!
Dale Kerr
03D
