Author Topic: 19N509257 DZ 302 Block on ebay  (Read 14177 times)
Re: 19N509257 DZ 302 Block on ebay
« Reply #15 on: February 21, 2018, 05:05:59 AM »
great info. Any ideas on why it was on the pad still so late into the spring. (all ZL-1's would have been Norwood I think)
« Reply #16 on: February 21, 2018, 08:15:39 PM »
Yup, all ZL1s were built at Norwood. No idea why some were VIN stamped on the pad.
ZLP955
« Reply #17 on: February 22, 2018, 11:34:38 AM »
What is the earliest vin stamped by the oil filter? what is the latest known vin stamped on the pad? (LA and Norwood examples if you have them)
I have 19L528xxx stamped on the pad, and have seen them into 19L530xxx (which is nearing the end of LA production for the '69 MY) also on the pad. By contrast, I know the current owner of 19L5023xx and it's stamped by the oil filter.....
Tim in Australia.
« Reply #18 on: February 22, 2018, 02:51:12 PM »
There was a federal requirement (from Aug/Sep '68) that the engine be 'uniquely identified, and VIN stamping is most expedient at time of installation , but there was no federal requirement on where it was stamped.
The issue of *where* the VIN was stamped on '69 engines, and the 'inconsistency' in location thru the year, makes me think that Chevrolet engineering management to address the requirement wrote specifications allowing for either location to be stamped (so long as ONE of them was); the LA and Norwood plants apparently chose different locations to meet this requirement.
It was probably faster/easier to stamp the engine low on the side, immediately before or after the transmission was stamped.  It's obviously easier to rear on the pad!  It may have varied with the person being tasked with that job, or possibly whether the engine was 'dressed out' with alternator/etc, or not, at the stamping time.
