Author Topic: Introducing the "GILMORE" 1968 Z28  (Read 245475 times)
169INDY
Re: Introducing the "GILMORE" 1968 Z28
« Reply #195 on: March 27, 2025, 04:48:06 AM »
Thanks: DuWayne, Darrel, Joe & Maroman.
I have been making progress towards the July Target Finish Date & Coming out Party & Shows.
Joe, I used the AMK tubular rivets and Hanson Buck-Peening tooling to Set the rivets for the end brackets. After Blasting, Prime, Powder coating of course a bit of silver overspray from the grill painting also. The Brackets are marked with Big "C"'s on the back side.
More progress to post soon.
68 SS/RS L35 Th-400 LOS
69 Pace Car L48 Th-350 LOS
68 Z28 M21 LOS
169INDY
« Reply #196 on: March 27, 2025, 05:13:41 AM »
Fuel-Gas Tank (Spectra Made in CA) Tern plated.  Restored Factory AC Delco 3/8" Fuel Pick up using Dorman Donor parts, ECS anti squeak pads, Anti Drum Pad, Repop Filler hose, Replated (*ZINC) 12/1967 Whittek tower clamps, Square tang Olive 3/8" spring clamps, Stamped 3/8" Hose, AMK Black Masking tape,
68 Z28 M21 LOS
169INDY
« Reply #197 on: March 27, 2025, 05:16:02 AM »
Tank associated - Filler GM Replated, Orig Gas Cap, Misc View Rear & Trunk.
68 Z28 M21 LOS
169INDY
« Reply #198 on: April 14, 2025, 04:26:25 PM »
Rear Qtr Marker Lights. GM (NOS) w/ Orig Polished Lens's.
Rear Taillights Sourced (CHQ) Very good quality products using Factory Molded Gaskets refurbished.  Meguire Plastic Polish on the GM Factory Lens's. Zinc plated GM Backs.
There is one Note: The Repop Housing will not accept the Factory Nuts, you must use the Supplied fasteners since the Threaded posts seem to differ.
68 Z28 M21 LOS
169INDY
« Reply #199 on: April 14, 2025, 04:31:56 PM »
More Work at the Rear of the Car:
GM Bumper Replated, Brackets Gloss Black, Replated GM Factory Guard's with NOS Rubber inserts, Don Lightfoot Reproduction Stickers, Correctly Date Jack Instr. & Glue on Posi Warning.
"DF" SPare with E70-15 G.Y. WT GT. Square Walker Jack,
Of Note: I could not replicate the (LOS) Van Nyes Trunk Spatter, I Overcoated the Aerosol done by the Prior Owner & could only Get the 'Dots' of Norwood and not the Stringy' Calif Style. It will have to do for now.
Oh & the Seller Dealer T&W Repop Frame w/ 'Year of Manufacture' WA plate from Whitman Co, City Pullman WA. where Washington State University since this coincides with the 1971-1972 Carr Pool Parking Permit on the Rear window.
68 Z28 M21 LOS
169INDY
« Reply #200 on: Today at 04:28:49 AM »
Front Bumper Install.
Including 68 Rubber Center "Bumper" valance bracket and Rubber.
Much Needed Front ID Plate LoL subject to Change and swap out with other front plates for shows.
Chevy the Helper center stage.
Replated Factory GM Front Bumper. Polished Original Stainless cap mounting bolts.
68 Z28 M21 LOS
rocco376
« Reply #201 on: Today at 10:17:56 AM »
Obviously, the final picture shows the true installer.  Looks great.
