Author Topic: POP axle code LJ1012G...LJ not in list?  (Read 5894 times)
tinhunter
« on: April 03, 2017, 06:17:40 PM »
Hi All,
I'm helping a friend with his 67 RS-SS convertible. The car is still apparently all numbers matching, and the block/cowl tag/Protect-o-plate match.  The only thing I haven't been able to decode is the POP axle code "LJ1012G".   "LJ" is not on any list I can find.
The car is an L48/4 speed/12 bolt, but I haven't been able to clean the axle tube yet to check the stamping.
Is this a typo? Should it be PJ perhaps?
Also, what's the proper nomenclature for a 67 Camaro with the 350SS option and RS package? If I had been at the dealership in '66, would the salesman have called this a 350SS, an SS-RS, etc? I always  got the sense that GM hadn't really figured how to brand these cars until later in 68 or 69.
Thanks!
Re: POP axle code LJ1012G...LJ not in list?
« Reply #1 on: April 03, 2017, 06:20:25 PM »
Take a clear pic of the axle code after you gently clean the area, then post a pic.
Also check the casting number and casting date.
http://www.camaros.org/drivetrain.shtml#axle
The only thing I am coming up with so far - for that code - is for a 1970 GTO.
Technically I am not sure which is correct. I would say 1967 Camaro 350 RS/SS  or 1967 Camaro SS350 with RS package.
« Last Edit: April 03, 2017, 07:00:50 PM by bcmiller »
tinhunter
« Reply #2 on: April 03, 2017, 06:51:34 PM »
Thank you -  I won't be able to get back to the car for a few days, but here's a shot of the POP.
I found the same reference to GTO codes, but its a little odd that it would show up in '67.   Also, for reference, the cowl tag build date is 10C.
 IMG_7685 by Shaun Guillermin, on Flickr
« Reply #3 on: April 03, 2017, 06:56:57 PM »
Most likely a typo on the POP, but check the axle tube.
« Reply #4 on: April 06, 2017, 02:55:28 AM »
Hey, Welcome to the site.
Also post pics of the rest of the car when you have a chance.
thanks! ;)
70L34
« Reply #5 on: April 06, 2017, 03:24:52 AM »
Just found the car on Ebay, see below. Neat car!
1967 Camaro RS/SS Convertible
« Reply #6 on: April 06, 2017, 04:06:00 AM »
124677N121501
tinhunter
« Reply #7 on: April 07, 2017, 02:58:35 AM »
Yep, that's her! I really wish I had the money to buy it myself. Its not a perfect car but how often do you find one that hasn't been hacked on...
Anyway, here are the numbers.
Axle - PJ1012G  E
Casting 389460
The code matches the POP except for the "LJ".  I guess this is one instance of a factory typo?
Also if anyone would like me to document any details, please ask. I'd be more than happy to share.
« Reply #8 on: April 07, 2017, 04:45:38 AM »
Thanks. Yes typo on the POP. Unusual but not unheard of.
Pics if the engine and transmission stampings would be helpful.
tinhunter
« Reply #9 on: April 07, 2017, 12:45:08 PM »
Sure, no problem.
