Needing some guidance on how to properly seat this style of brake and fuel line clip.
The first question I have is how tight to the frame should they be after being seated? Should they be pressed tight against the frame or have some clearance? ......If they are supposed to be pressed tight against the frame, should you still be able to rotate them?
Second question is what do you use to expand the rivet head so that they hold tight in place?
To experiment, I drilled a hole in a piece of scrap metal that is the same thickness as the frame and made the hole the same diameter as the mounting hole for these clips. I put a used clip in the hole and them hammered a rod (same diameter as the inside diameter of the rivet) with a rounded head into it trying to mushroom the rivet on the backside of the hole.......What you see in the second picture was the best I could do. Not tight at all. Very, very loose!
Any suggestions
Thanks......Dave
