Author Topic: 68 camaro blower motor with AC  (Read 8337 times)
dale68z
« on: December 19, 2016, 11:01:40 PM »
I daily drive my 68 camaro. I am in need of a squirrel cage for the blower motor with AC. The center aluminum hub had come loose and was noisy. I replaced the motor, thinking it was the source of the noise. When I transferred the cage I found the center hub loose. So I peened it to tighten it. I must have gotten it out of balance. I really don't want to do the job again without all the correct parts.
 I have not found a vendor with a blower cage for an AC car. Some vendors say the  67-81 non ac is the same as the 67-9 ac blower motor/ cage.
  Can anyone confirm the difference in blower motors or squirrel cages between ac and non ac cars?
 Can I use a motor/ squirrel cage from a different vehicle?
1968 Z28
Re: 68 camaro blower motor with AC
« Reply #1 on: December 20, 2016, 12:17:02 AM »
Info from my 1967-1969 Camaro Master Parts Catalog
8.855  Motor Assembly,  Heater Blower
      4918686     1967-1969/ALL  -  Delco Motor  /SUP/  4914901
      3405466     1967-1969/ALL  -  GM Motor  /SUP  5736086
Might Google these numbers and see what shows up.
Jerry G.
Z28-1968-07C-Norwood
2nd. Owner, 38,000 miles
rare396bronze
« Reply #2 on: December 20, 2016, 02:55:41 AM »
With ac original blower motor #4914916 fan #3144684. With out ac blower #4914901 fan# 3905776. GM later on superceded fan 3144684 to 3095776. Ac fan motors had a hole for cooling hose non ac cars did not have hole in motor. I would look for 64-71 Chevrolet for fan with  ac. Hope this helps.
« Reply #3 on: December 20, 2016, 03:23:12 AM »
Contact THIS GUY and see if he still has it. It was on ebay back in November with no bidders.
Z28Project
« Reply #5 on: December 20, 2016, 04:25:55 AM »
Man, you guys are on top of everything!  :)
John
dale68z
« Reply #6 on: December 20, 2016, 05:04:42 AM »
Thanks, awesome information.
  Interesting the 684 fan for AC was replaced with the 776 fan originally meant for non AC cars.
« Reply #7 on: December 20, 2016, 01:51:05 PM »
When it comes to blower motors, GM made a one size fits all, or close to this statement. There are a bunch of GM cars from that era that have the same motor and I assume squirrel cage according to my Hollander interchange manual. PM me if you want one of these cages...pretty sure I have what you need.
« Reply #8 on: December 20, 2016, 02:36:04 PM »
Quote
Ed, he sold it on 12-7-16...
Darn, didn't see that Paul. Thanks.
Quote
MILLIONS!! (If not hundreds of millions!) Go to THIS SITE and put in 3144684 and you'll see all the cars and trucks it was used on!
Petes L48
« Reply #9 on: December 20, 2016, 03:53:12 PM »
FWIW, when I took mine apart to clean it up it had a metal clip or two on the hamster wheel blades, presumably to balance the thing, like balancing a wheel.  This is a C60 A/C car.
dale68z
« Reply #10 on: December 23, 2016, 03:28:24 AM »
Found a friend w a 70 vette fan, and another with a 67 chevelle fan. Both should be the same as my camaro with AC. Thanks guys for the information.
