Author Topic: engine mount part numbers  (Read 7293 times)
My68SS
« on: January 08, 2007, 10:12:51 AM »
Hi all, just wondering what engine/vehicle these engine mount part numbers belong too.
3955183
3980938
Cheers.
edit: modified this post to reflect the correct number as per Lakeholme's post below
« Last Edit: January 26, 2007, 05:48:59 AM by My68SS »
Rob
1968 12C SS
L34/M40
12 bolt posi 3.55
lakeholme
  • 68-12D L30/M35
Re: engine mount part numbers
« Reply #1 on: January 08, 2007, 02:58:27 PM »
Looks like 67-68 302 engine mounting brackets...
Check 3955783 and see if the 7 is a 1 = 3955183...
72 P&A 30A says:
           0.029 BRACKET, engine mounting
67-68  All (302).....3955183 L.H.     2.00   engine mtg. to side member
67-68  All (302).....3980938 R.H.     2.00   engine mtg. to side member
My68SS
« Reply #2 on: January 08, 2007, 03:34:46 PM »
My bad, it is 3955183. That's what happens when you hastily scrawl notes on the palm of your hand!  :)
Just edited the pn in the first post
So, Z28 mounts are they? Whats the difference between them and other small block mounts from those models?
Thanks for the info.
btw, the RH mount is taller than the LH one, if thats of any help or significance.
« Last Edit: January 08, 2007, 03:38:10 PM by My68SS »
Rob
1968 12C SS
L34/M40
12 bolt posi 3.55
lakeholme
  • 68-12D L30/M35
« Reply #3 on: January 08, 2007, 04:02:53 PM »
My68SS
« Reply #4 on: January 09, 2007, 08:07:00 AM »
Ok, if I'm reading this right, these brackets fall into group B of the bracket list? which covers all 67 - 69 sbc excluding 69 302, 350.
Which would mean they're not exclusively 302 mounts, just standard sbc mounts covering all 67 - 68 sbc (including) 302 ?
Rob
1968 12C SS
L34/M40
12 bolt posi 3.55
