Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Restoration
Washer/Wiper Cog
« previous
next »
Print
Pages: [
1
2
All
Author
Topic: Washer/Wiper Cog (Read 14206 times)
67rs327
Member
Washer/Wiper Cog
on:
July 27, 2016, 01:19:31 AM »
So I needed to replace both my wiper motor and washer pump ('67) because the previous owner had Frankensteined a motor from what I think was a 60's truck and a pump that looked like a Jarvik 7 (some of you may remember what that was) to the firewall. After attaching both aftermarket parts - I went to fit from the old wiper motor what I'll call the "washer cog" - its a 4 pointed "star" which is 9/16 thick and is 1-1/8 tip to tip. Although it fits the shaft perfectly - it seems a little long and the washer pump housing does not fit well over it (like it would bind if activated). Looking to see if anyone can confirm the correct dimensions? Thanks - Chris
Tweet
Logged
1967rs L30/M20 Bolero Red - LOS 11A.
Chris - New Hampshire.
67rs327
Member
Re: Washer/Wiper Cog
Reply #1 on:
July 27, 2016, 01:25:44 AM »
Better picture.....
Logged
Hero Member
Reply #2 on:
July 27, 2016, 02:15:32 AM »
I measured the gear on my '67 and it is the same dimensions as yours in width (1 1/8") and thickness.
Have you rotated the gear so that it can slide into the pump housing easily?
Logged
67rs327
Member
Reply #3 on:
July 28, 2016, 12:08:01 AM »
Thanks for the confirmation Mike. I'll try repositioning the pump and see if that works now that I know that cog looking part is the right size.
Logged
Hero Member
Reply #4 on:
August 02, 2016, 11:50:24 PM »
Hi Chris,
Just curious if you were able to get the pump body on.
Logged
67rs327
Member
Reply #5 on:
August 15, 2016, 12:42:07 PM »
Mike - sorry for the late reply. Life always getting in the way.
Still struggling with that gear. I have it pushed all the way down - but there is a shoulder on the shaft that's keeping it from going on far enough and its hitting the casing on the back of the pump. Its a rebuilt wiper motor so now I'm wondering if the shaft was not set correctly?
Logged
Hero Member
Reply #6 on:
August 15, 2016, 01:03:05 PM »
Hmmmm.....let me measure the gear depth on mine and let you know later today. The washer is off the car still so it's easy to do.
Logged
Hero Member
Reply #7 on:
August 15, 2016, 01:25:00 PM »
Here is a closeup of the gear mounted. The ruler increments are in 1/16". Measuring from the mounting surface the set depth looks to be 1/4" to the gear end. Then starting at the 1/2" mark to 3/4" is the thickness of the star tooth.
Let me know if you need any more measurements or pictures. This assembly is off the car during the restoration.
Logged
67rs327
Member
Reply #8 on:
August 16, 2016, 03:34:12 PM »
Yep - the issue appears to be the total thickness with the gear on. Yours is at 3/4 and I'm at 7/8 (just the gear at 1/4 thick is spot on so its not the gear) Shaft is sticking out too far. Now what to do?
Logged
Hero Member
Reply #9 on:
August 16, 2016, 03:44:13 PM »
I haven't had the star gear off so I'm not familiar how the shaft looks. If the star gear depth is set by the star gear itself then would it be possible to shave 2/16" off the shaft end thereby allowing the gear to sit lower?
Logged
67rs327
Member
Reply #10 on:
August 18, 2016, 03:30:50 PM »
Reducing the overall length of the shaft I don't think will work. The gear is down as far as it will go b/c of the machining to make 2 flat sides so the gear does not spin (i.e. so the gear turns with the shaft). Not knowing the internals of the wiper motor - I think it will need to be pressed in 1/8 of an inch? Electrical part so I can't return it
Logged
Hero Member
Reply #11 on:
August 18, 2016, 04:00:12 PM »
How does that gear come off? I can try to remove mine and measure the exposed shaft length.
Logged
67rs327
Member
Reply #12 on:
August 19, 2016, 01:55:11 PM »
Mine just pulls right off. No set screw or anything. The way it's designed once the pump is attached I don't think there's any chance it could come off the shaft.
Logged
Hero Member
Reply #13 on:
August 21, 2016, 03:30:56 PM »
The gear doesn't resemble what I have always worked with. Is it a cast metal gear ? All mine are thinner nylon gears, white, and a lot closer to the gear case when installed.
I'll get a pic later this morning -
Logged
1969 Z11 L48/M35/C60/C06 1949 3100 5wd 235/6
Hero Member
Reply #14 on:
August 21, 2016, 05:14:57 PM »
At least in 67 a metal gear was used. I have a couple of spare '67 motors and they all have metal gears.
Let me try to remove mine and I'll get measurements.
Logged
Print
Pages: [
1
2
All
« previous
next »
Restoration
Washer/Wiper Cog
