Author Topic: Dash suede paint  (Read 10728 times)
69z27z87
  • The garage - my happy place
Dash suede paint
« on: July 24, 2016, 04:17:09 PM »
I had to replace the dash due to rot at the bottom...
I do I replicate the suede paint finish on the dash?
Is there a particular product to use?
1969 SS396 - L35, Z87 Daytona Yellow, Yellow Houndstooth, Black Vinyl top
1992 Z28 - LB9 Purple Haze, T-5WC, grey leather interior
Hans L
Re: Dash suede paint
« Reply #1 on: July 24, 2016, 05:26:42 PM »
Yes.  I assume it's for a '69 Camaro?   PPG offers in Duracryl DDL.   Ref # DIA 9317.   It is lacquer, so not easy to get.   I'm not sure if there other paint types that offer the same finish.
You can try TCP Global - they maybe able to order it for you as long as you live in state where you can buy lacquer paint.
Instrument Specialities sells it as well:  http://www.instrument-specialties.com/products/
'69 Chevelle SS 396 4 Speed
'70 Camaro SS L78
77thor
« Reply #2 on: July 24, 2016, 05:28:20 PM »
I used a black 'satin' finish spray can. It turned out very nice.
m22mike
« Reply #3 on: July 24, 2016, 06:42:39 PM »
Get the PPG DDL, or mix your own, if your a painter, use lacquer. You can not get close with a rattle can. Take the time to look at some original GM cars.
6667ss138
« Reply #4 on: July 24, 2016, 07:32:21 PM »
I just recently ordered my suede lacquer dash top paint from TCP global for my 66 Chevelle. Was no problem to get at all. It was not any more expensive than the base coat paint that my painter was going to get from his local jobber. It has turned out great, much more factory correct and I am really glad we are using it opposed to the base coat paints.
I talked to a guy named Jimmy Chips. He is an old paint rep from back in the 70's. Great guy, very knowledgeable and friendly. My 66 is a factory red interior car and he was a great help in looking up the correct 0 gloss dark red color.
Here is his number  858-909-2150  Ext. 135
Hope this helps.
Hans L
« Reply #5 on: July 24, 2016, 07:41:29 PM »
I may have try Jimmy Chips at TCP Global.   They used to sell me the lacquer over the counter but about 2-3 yrs ago, they said they couldn't sell it anymore to someone with a Cali address (I live in San Diego).  So I ship it to my parents in WA state and they send it back to me....
'70 Camaro SS L78
manyc
    • Relic Recyclery
« Reply #6 on: January 24, 2018, 05:53:55 PM »
Just wanted to add that I was able to buy suede lacquer from these guys for a Chrysler I was working on:
http://www.instrument-specialties.com/products/manufacturers/gm/
I just needed to locally buy good old DTL16 to reduce it with.
Obsessed amature restorer. Cars include 1969 Firebird 350 Conv, 1967 Camaro RS/SS conv Blue-Topper, several limited edition 1969 Mustangs, Panther Pink 1970 Challenger, 1963 Jaguar E-Type.
"If I can't fix it, I will fix it so no one can!"
Pacecar
« Reply #7 on: January 25, 2018, 04:58:57 PM »
SEM makes a textured paint as does Rustoleum in spray cans. If you experiment with the distance that you are spraying I think you can replicate the suede finish. I used it on the heater under the dash and thought it came out fine. Heater also receives the suede paint. Trying to keep my original dash paint though.
« Reply #8 on: January 25, 2018, 07:12:46 PM »
I stock SEM texture coating in quarts and gun spray it. It provides more control, and allows reducing to alter the texture. Then topcoat with the color of choice. Far more economical than lacquer at $100 per pint.
KevinW
« Reply #9 on: January 26, 2018, 12:49:52 PM »
I used Krylon flat camo paint, I think it did the trick.  Does not have the deep orange peel look, but next time I will get the base to the proper texture, then put the camo as finish coat.
« Reply #10 on: January 26, 2018, 02:11:14 PM »
I was able to duplicate my 67's NOR dash (using my 67 LOS as a reference) using Rustoleum 7220 textured paint. The 7220 gloss looks semi so for the dash top I used the 7220 texture sandwiched between flat paint coats (ex: black primer, 1 coat flat, 1 light coat of 7220 for texture, 1 coat flat) so as not to build up the texture thickness. Looks excellent and factory.
