Author Topic: What fender do I need?  (Read 14647 times)
greaser
« on: January 17, 2016, 01:52:35 AM »
Ok so I have a roller 68 it has a badge on the back that says it's an rs but thats all I see.The front fender does need an extension.I was going to order a replacement online but it says the one I was looking @ won't fit a 68 rs so I need to know what to look for so that I can purchase the correct fender?Thank you & I hope that I am posting in the right section.
jvb6648
  • 716-796-5263
Re: What fender do I need?
« Reply #1 on: January 17, 2016, 02:26:19 AM »
If you have hide away headlights and lights in the lower valance you probably have a RS.
68 Z/28
HustleRussell
« Reply #2 on: January 17, 2016, 03:37:29 AM »
Welcome to the best Camaro website ever. If your Camaro is a factory RS the reverse back up lights will be located below the bumper.
Russ
68 RS
69 SS
vtfb68
« Reply #3 on: January 17, 2016, 04:12:13 AM »
Greaser,
 Get one to match the other side. Pay close attention to the headlight bucket mounting tab location.
  VT
68 08E LA RS Y2 749 L30 M35
greaser
« Reply #4 on: January 17, 2016, 06:18:26 AM »
Thank  you guys I read the forums & looked @ the monts they look like non rs I think someone just put a rs badge on the back,also will rear  quarters work from a Coupe to An rs?I am new to these cars,More of a gasser enthusiast as lately.Before that g-body's &mopars.I do bodywork & have meant to put quarters on this thing but the ones that came were some cheap chinese ones I won't even attempt to put em on.I have the orginal fender but it's pretty nasty.
« Reply #5 on: January 17, 2016, 07:29:32 AM »
Greaser,
See "Rally Sport (Z22)" in the following CRG link...
http://www.camaros.org/options.shtml#id
greaser
« Reply #6 on: January 17, 2016, 12:09:49 PM »
Thanks after finding pix online of the way a rs vs non rs should look around the headlamps & the vin decoded I've figured it out to be a non rs
« Reply #7 on: January 17, 2016, 09:22:59 PM »
Nothing on the VIN tag or on the Fisher Body tag will tell you whether it is an RS or not on a 68.
See this link for more data on 68 Camaros.
http://www.camaros.org/diffs68.shtml
Then see this for the RS option.  Scroll down a bit.
« Reply #8 on: January 18, 2016, 12:06:09 AM »
RS badge does not go on the back.
greaser
« Reply #9 on: January 18, 2016, 02:24:08 AM »
Its by the keyhole or
 the trunk it has a big red&white circle with a glass/Plastic cover with a
R
S
Gramps69Z
  • 69 X33 D80
« Reply #10 on: January 18, 2016, 02:50:51 AM »
Is that not your gas cap?
Captain John Wykoff
greaser
« Reply #11 on: January 18, 2016, 02:57:39 AM »
You know what it probably is,for somereason I thought the gas cap was under the licensce plate,Geez Im a knucklehead.
« Reply #12 on: January 18, 2016, 03:21:51 AM »
Does it look like this?
« Reply #13 on: January 18, 2016, 04:25:13 AM »
Good grief!!
Gramps69Z
  • 69 X33 D80
« Reply #14 on: January 18, 2016, 04:38:01 AM »
You need to post some pictures of the car so we can get a good look at it.   8)
Captain John Wykoff
