Author Topic: 0-385138. 327 block help id  (Read 16875 times)
camarosx3
« on: October 12, 2015, 05:05:28 PM »
I got this block in nova project I picked up...never seen this block casting number..please help
I do have the 11 to 1 gm/trw forged pistons and weird oil pan and long oil pump pickup tube
Any help would be appreciated
Kelley W King
Re: 0-385138. 327 block help id
« Reply #1 on: October 12, 2015, 06:21:55 PM »
The nova pan was unique. What is date on the block? It could a Corvette HP motor.
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
camarosx3
« Reply #2 on: October 12, 2015, 06:26:00 PM »
93206-f...is on the front pad
camarosx3
« Reply #3 on: October 12, 2015, 06:31:25 PM »
May 1967
Kelley W King
« Reply #4 on: October 12, 2015, 07:38:49 PM »
you sure that- is not an H
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
camarosx3
« Reply #5 on: October 12, 2015, 07:56:16 PM »
H on front pad or build date
camarosx3
« Reply #6 on: October 12, 2015, 08:17:07 PM »
« Reply #7 on: October 12, 2015, 11:16:23 PM »
Wondering if it may be one of the change over blocks when the '67 Novas were converting away from the L79 327's in preparation for the 350 conversions. One of those '67's is around here somewhere, a series of them built in April - June '67, P-O-P coded as an L79, with a apparently original 255 HP block (or 275 block - help me, DW) - I wish I could remember the casting number. I'll look for the article describing this -
camarosx3
« Reply #8 on: October 13, 2015, 12:59:55 AM »
It has spin on oil filter...Also the webbing reinforcing the block is really thick
camarosx3
« Reply #9 on: October 13, 2015, 11:31:51 PM »
« Reply #10 on: October 14, 2015, 04:53:19 PM »
The O-385138 pegs it as an experimental casting, and the 98206-F on the pad pegs it as having been built in the Motor Room at Chevrolet Engineering, authorized by the sixth supplement ("F") to Engineering Build Work Order #98206. If you had the BWO (Build Work Order) files from 1967, you'd have the details, but we don't.  :-\
camarosx3
« Reply #11 on: October 14, 2015, 05:27:02 PM »
What's it worth...I have the trw forged pistons and rods..std bore pistons...I have the steel crank also
« Reply #12 on: October 15, 2015, 01:18:23 PM »
Not sure how I missed this thread..  You could have called..   :P  You going to Oktoberfest this weekend?  Also Snow White is having a car show benefit on Saturday..  Probably taking the 67 to one or both.
Im hoping that 67 will end up in my garage one of these days but Im not holding my breath..  Ill look tonight when I get home..  I have pics of the pop, car, engine & trans.  Pad was stamped ZA (POP is ZI) but when rebuilt in the 70's it had dome pistons, cast intake, q-jet.  Still has the correct dated flywheel which is the same as a 67 Z.
As John has already stated its an experimental block.  Ive seen intakes with this casting or stamp but this is a first for me on a block.  Pretty cool piece.
« Reply #13 on: October 16, 2015, 01:55:29 AM »
Couple questions..  What type of balancer does this engine have?   Also the number on the crankshaft?  Pics of the pistons would be great too..  This is starting to peak my interest..   :)
« Reply #14 on: October 16, 2015, 02:55:02 AM »
I'll be at Oktoberfest Sunday for sure. Did not hear about Snow White - all day or evening ? Great weekend for both - see you at one or the other.
Hope the '7 finds it's way to your garage - I'd be jealous !
