Author Topic: 69 RS Washer Bottle Bracket Fasteners  (Read 8165 times)
RS_COPO_Canuck
« on: April 09, 2015, 05:23:10 PM »
Hi All. Trying to figure out the correct fasteners and plating for the washer bottle bracket. The ones on there are phos finish (don't have the head marking info at the moment).....the ones that come in the kit are silver and have caps that go over the exposed threads...which are shown in the manual. Again - can't tell you (at the moment) the markings on those either. Thanks!
zman1969
Re: 69 RS Washer Bottle Bracket Fasteners
« Reply #1 on: April 15, 2015, 09:16:33 PM »
the original screws had plastic caps that are not being reproduced Hearbeat supplys a rubber vacuum cap which is similar but not correct. Im thinking I have a picture on my home computer - I'll see if I can find and post it up
Rich
69 RS/Z DZ302 Daytona bumble bee
69 T/A clone LS6/6sp
69 Nova SS 396
zman1969
« Reply #2 on: April 15, 2015, 11:44:04 PM »
here you go
Rich
69 Nova SS 396
« Reply #3 on: April 16, 2015, 04:26:08 AM »
ID x OD x LG ??
zman1969
« Reply #4 on: April 16, 2015, 12:35:34 PM »
I dont know, someone else took the pics. seems like would be simple enough to reproduce
Rich
69 Nova SS 396
RS_COPO_Canuck
« Reply #5 on: April 17, 2015, 01:16:37 PM »
Thanks for the cap info Rich - much appreciated. I assume the caps are used on all of the bolts....both on inner fender and bottle bracket? I'm going to see if I can source those caps. Would you say those screws were silver cad plated?
« Last Edit: April 17, 2015, 02:50:30 PM by RS_COPO_Canuck »
« Reply #6 on: April 17, 2015, 03:27:26 PM »
One more pic ,originals off of my car ;) 8)
Yes, the 3 screws that mount bracket to the inner fender also get a cap, but it is smaller. BTW, I have three of these brackets and each example has a different type screw mounting the bracket to inner fender?? Not sure why. Would like to see what others have hardware wise. AIM Z22,B4, item #4, 9420890 (qty.3) is the screw for bracket to inner fender used. 3767304 is cap for that screw.
Here is a hint of a source to make your own:   http://www.autopartswarehouse.com/shop_parts/diesel_injector_plug/mercedes_benz/300d.html
 In another life, I was a Master M-B Technician.
« Last Edit: April 17, 2015, 04:04:04 PM by ko-lek-tor »
RS_COPO_Canuck
« Reply #7 on: April 17, 2015, 04:23:50 PM »
Another great pic - thanks!  Are those MB plugs closed on one end?
« Reply #8 on: April 17, 2015, 04:28:21 PM »
Yep, that is why they are a PLUG. I use to put these on cars. It goes on last injector to plug it off. Just my own thought to use these for this purpose because they are squared off at the top. They are rubber, not plastic, but who will know? Take a razor knife and cut length of them down to fit.
RS_COPO_Canuck
« Reply #9 on: April 17, 2015, 05:24:24 PM »
Haha - I had to ask....hard to tell in the pic. Thanks again.
« Reply #10 on: April 18, 2015, 02:42:08 PM »
I now someone who had a thousand or so made by a plastics injection molder from an original cap he had on a survivor. Total cost was about $600.
Edgemontvillage
« Reply #11 on: April 18, 2015, 02:59:29 PM »
here you go
Rich, would you measure and post the length of the caps please?
zman1969
« Reply #12 on: May 24, 2018, 08:05:34 PM »
Bringing this back up, a couple weeks ago at swap meet I found a washer bottle, cap bracket and RS bracket with 2 out of the 3 caps intact so I bought it - check this thread for measurements and more pis if y'all need -Lloyd?
http://www.camaros.org/forum/index.php?topic=452.msg5985#msg5985
James the guy that had them made up is he selling these? I know its been 3 years
and lastly do y'all wanna know how much its was?
$1  ::)
Rich
69 Nova SS 396
« Reply #13 on: May 24, 2018, 09:00:08 PM »
Wow, he had a whole batch made from one, and likely only used 3 of the 600. What happened to the rest?
Edgemontvillage
« Reply #14 on: May 25, 2018, 04:57:20 AM »
$1  ::)
The simulated caps that were on the 10 10 RS/Z survivor (that James made up?) were discarded when I discovered they were not original. They appeared to be made from a fiberous material (rather than plastic per the originals) so I replaced them with an original set I located at the time.
