Author Topic: Firewall Wiring Gutter  (Read 5694 times)
« on: April 09, 2015, 03:45:58 AM »
What was the length of the original plastic wiring gutter that attaches to the firewall? I have 2, not sure which (or even if either) is correct for an 04A of 1969 Coupe. One measures 12", the other is just over 13" (both are slightly bowed, hence the approximate measurement). They have the correct end profile, so confident both are GM.
My68SS
Re: Firewall Wiring Gutter
« Reply #1 on: April 09, 2015, 10:55:54 AM »
My 12C 68 is just over 13". Original p/n is 3864327 superseded to 3923912 according to april 1970 PnA.
It took me a while to hunt it down in that dinosaur of a book [listed in the index as Retainer chassis wiring harness]
It's in grp 2.559, last entry and I quote:
65 - 69 All ....3923912  Retainer firewall wiring [13" O.L.] gen. and forward lamp harness to rad. tie bar [Note 1]
Note 1 reads - Loose trough type wire and hose retainer [rubber] use at cowl or radiator tie-bar locations as service replacement for similar retainers which are part of wiring harnesses.
Rob
1968 12C SS
L34/M40
12 bolt posi 3.55
« Reply #2 on: April 09, 2015, 10:01:23 PM »
Thanks Rob!
m22mike
« Reply #3 on: April 12, 2015, 12:10:55 PM »
I believe the 12" one is for Chevelle.
« Reply #4 on: April 12, 2015, 12:57:20 PM »
Great, appreciate the help Mike!
I had some bits and pieces from a '70 Chevelle LS6, maybe that's where the 12" version came from.
