Author Topic: 67-69 Bumper Jack Design  (Read 173758 times)
hihorse
Re: 67-69 Bumper Jack Design
« Reply #60 on: March 31, 2017, 10:41:31 PM »
base with "U"
« Reply #61 on: April 01, 2017, 04:01:24 AM »
Is there a patent number on the post shaft, near the top of the tube?
That's the more common base from what I've seen.
« Reply #62 on: April 01, 2017, 01:00:51 PM »
Sorry I never replied to your post Tim.  I recently acquired a correct jack assembly for the green car 08C (THANKS SPORT!!!!).  Unfortunately I did take any pics of it before putting it in the car.  Here are pics of the base from a few years ago.
hihorse
« Reply #63 on: April 01, 2017, 01:05:37 PM »
don't see a patent #. Also have a 9A with no patent # but my 9J does have one.
« Reply #64 on: April 03, 2017, 02:38:13 AM »
Interesting. I have two 8L's - both have the patent. 8A does not.
« Reply #65 on: April 03, 2017, 11:22:33 AM »
Ill look on my 8C next time I have it out.
« Reply #66 on: May 18, 2017, 07:18:42 AM »
Got another data point from Austin (thanks!) on his recently-purchased 10B LOS Z/28. Will add some pictures shortly.
67:
LOS 04B - square, 7D on the mast. Base - blank
NOR 05B - trapezoid, no date on rivet. Mast stamped CC07. Base U
68:
LOS 02C - square, 81 on the mast.  Base - blank.
LOS 02E - square, 8B on the mast.  Base - blank.
NOR 04A - trapezoid, 8C on rivet.  Base - blank.
NOR 04D - trapezoid, 8D on rivet.  Base tbd.
NOR  ? ? - trapezoid, 8D on rivet.  Base n/a.
69:
LOS 09D - square, 8J on the mast.  Base - blank.
LOS 10B - square, 8J on the mast. Base - blank. VE3 load rest.
LOS 01B - square, 8 on the mast.   Base - blank.
NOR 11D - trapezoid, 8L on rivet.  Base U69.  (note: convertible, space saver)
NOR 03B - trapezoid, 9C on rivet.  Base U69.
NOR 08E - trapezoid, 9G on rivet.  Base - blank. VE3 load rest
NOR 09C - trapezoid, 9H on rivet.  Base U69.
« Reply #67 on: May 18, 2017, 11:04:16 PM »
Here's the pictures from Austin:
Jack Base
End view of square jack mast:
Mast and ratchet mecanism:
VE3 load rest:
BillOhio
    • photobucket
« Reply #68 on: June 14, 2017, 08:15:02 PM »
Norwood 03D, 69
I will look at the mast when I can. My base does say U69 on it
1968 RS 327 4 speed
jdv69z
  • 69 RS Z/28 52E
« Reply #69 on: June 15, 2017, 01:00:15 PM »
I have my original jack. Is there info needed from it? If so, what info is needed?
Jimmy V.
« Reply #70 on: June 16, 2017, 09:56:21 AM »
Jimmy if you look back at the very first post at the top of page 1, you'll see the data required. Always good to get more to add in - so thanks in advance!
jdv69z
  • 69 RS Z/28 52E
« Reply #71 on: June 16, 2017, 12:35:33 PM »
Got it. I'll check mine out, and add whatever I can.
Jimmy V.
Mikes69_Coupe
« Reply #72 on: July 24, 2017, 03:56:15 PM »
Howdy all. Just figured I'd add to the list. This is the orig jack.
Norwood;
1969;
11A;
Trapezoidal;
U69 on the base;
8J on the rivet;
Camaro on the first line & 1969UN on the second line on the hook;
Nothing on the mast itself.
69 plain jane unrestored (but painted once) coupe, LeMans Blue, 86,264 miles, 327/210; PG; PS; A/C; Tinted glass. Original owner.
« Reply #73 on: July 27, 2017, 08:27:17 AM »
Thanks for the data Mike. I still have to download and re-post all the missing photos from this thread, thanks to Photobucket's recent TOS update, so I'll pick up all the new additions in that update.
JKZ27
« Reply #74 on: August 06, 2017, 05:28:27 PM »
1969 SS coupe
12B Norwood
Trapezoid w/ Patent 3163925
U69 base
8L rivet
Mechanism Lever has a small "UN" and big "UP"(with arrow).
John
John
68 RS Ash/Ivy Gold 327EFI M20
