Author Topic: Recommed 67 R/S lower mouldings?  (Read 6786 times)
« on: November 28, 2014, 08:24:52 PM »
 Because the R/S door/quarter/fender molding is old and pitting I am looking to replace it for the '67 convertible that's under restoration. Are all the reproductions I see available (examples: Classic Industries or D&R) the same quality?
I see one set that uses metal clips to secure the molding to the lower door instead of nylon so I'll reuse the original nylon ones.
Thank You,
Sauron327
Re: Recommed 67 R/S lower mouldings?
« Reply #1 on: November 28, 2014, 10:53:52 PM »
I've used 3 sets of Classic Headquarters and was not disappointed with their repro quality. If you want better buy NOS. Ask the vendor which ones they selll. Not sure if anyone besides CHQ makes them.
« Reply #2 on: November 29, 2014, 12:39:16 AM »
 Thank you, Sauron. CHQ it is.
Sauron327
« Reply #3 on: November 29, 2014, 02:19:07 AM »
I should not have to state this but I will nonetheless. You will have to fit the repro moldings and may have to hand file the ends for a proper fit. Fitting parts on a resto is common practice whether it is GM or repro.
« Reply #4 on: November 29, 2014, 02:25:00 AM »
   Can I assume the 90 degree bends on the ends are correct and just the very edges need to be filed to fit?
Thanks for the info,
« Reply #5 on: November 29, 2014, 02:24:14 PM »
Agree with Sauron.  I had to drill the quarter ends inside the door frame.  Also you might want to tighten the channel that the clips ride in.  Mine were a tad loose.
« Reply #6 on: November 29, 2014, 02:54:03 PM »
Hi Darrell,
  Drill as in...widening the hole to get them aligned with the body hole? When all is done, does it looks 'natural'?
« Reply #7 on: November 29, 2014, 04:31:40 PM »
My car had new quarters so I had to drill the holes.
Sauron327
« Reply #8 on: November 29, 2014, 06:25:51 PM »
67 RS moldings not the same as 68 and mount differently.
« Reply #9 on: November 29, 2014, 09:18:15 PM »
I am well aware.  I have both..   ;)
Sauron327
« Reply #10 on: November 29, 2014, 09:26:48 PM »
You simply have to file the ends so they don't dig into the paint. Same goes for repro rocker spears. Installation is self explanatory and reallly no big deal. The repro clips supplied are not tall enough and extensions must be welded to them. I've had to do this more than once. Again, piece of cake.
« Reply #11 on: November 29, 2014, 09:39:55 PM »
 Understood!  Before I use the clips that come with it I'll try the original nylon ones.
Thanks again all,
