Camaro Research Group Discussion => General Discussion => Topic started by: Mike S on November 28, 2014, 08:24:52 PM
Because the R/S door/quarter/fender molding is old and pitting I am looking to replace it for the '67 convertible that's under restoration. Are all the reproductions I see available (examples: Classic Industries or D&R) the same quality?
I see one set that uses metal clips to secure the molding to the lower door instead of nylon so I'll reuse the original nylon ones.
Thank You,
I've used 3 sets of Classic Headquarters and was not disappointed with their repro quality. If you want better buy NOS. Ask the vendor which ones they selll. Not sure if anyone besides CHQ makes them.
Thank you, Sauron. CHQ it is.
I should not have to state this but I will nonetheless. You will have to fit the repro moldings and may have to hand file the ends for a proper fit. Fitting parts on a resto is common practice whether it is GM or repro.
Can I assume the 90 degree bends on the ends are correct and just the very edges need to be filed to fit?
Thanks for the info,
Agree with Sauron. I had to drill the quarter ends inside the door frame. Also you might want to tighten the channel that the clips ride in. Mine were a tad loose.
Hi Darrell,
Drill as in...widening the hole to get them aligned with the body hole? When all is done, does it looks 'natural'?
My car had new quarters so I had to drill the holes.
67 RS moldings not the same as 68 and mount differently.
I am well aware. I have both.. ;)
You simply have to file the ends so they don't dig into the paint. Same goes for repro rocker spears. Installation is self explanatory and reallly no big deal. The repro clips supplied are not tall enough and extensions must be welded to them. I've had to do this more than once. Again, piece of cake.
Understood! Before I use the clips that come with it I'll try the original nylon ones.
Thanks again all,
