Author Topic: 67 camaro converted from straight 6 to BB  (Read 5875 times)
Jbyer8
« on: August 13, 2014, 02:31:04 AM »
Looking to purchase a 67 camaro. The vin indicates that it was originally built as straight 6. It has since been modified with a 396 engine, muncie 4 speed, 12 bolt Posi rear end, and 3 row radiator with electric fan.
Is there anything I should be leary about when dealing with this type of mod? Anything else that should have been changed or upgraded?
Re: 67 camaro converted from straight 6 to BB
« Reply #1 on: August 13, 2014, 06:57:11 PM »
 The BB also used a larger diameter fuel line and heavier duty springs in the front.
Being the mod was done already I assume things like transmission mount offset, engine mounts, etc are done properly. That's all bolt on parts anyhow.
I assume the 12 bolt doesn't have the traction bar perch and floor bracket. No big deal if it is not there.
L78 steve
« Reply #2 on: August 14, 2014, 07:31:06 PM »
Radius rod not needed if Cal-tracs or slapper bars used.
69 Z/28 Dover White. SOLD
