Author Topic: Need engine # help  (Read 14536 times)
joemac8
Need engine # help
« on: November 10, 2005, 11:08:45 PM »
I bought a 67 Camaro convertible today.  It has a 6 cyl and auto trans.  I tried to look up the numbers on the pad near the distributor.  All that I found was F0907FM.  This was under paint which I cleaned away.  I thought that a derrivitive of the vin should be located below the other number on the pad but there is nothing that I can see.  The number above is in the center of the pad.
The casting number on the motor is 3877178 above GM which is above 4.
Can someone tell me, could this be the original motor for my car?
Z71
    • Amsoil Jobber
Re: Need engine # help
« Reply #1 on: November 10, 2005, 11:31:03 PM »
Yes
FM is a 1967 Camaro 250 cid with powerglide trans
You won't find a VIN on it.  That was not done till 1968 and beyond.  Prior to 68 was only on hi-perf engines
Owned new (and still have stashed away) LOL
1966 Impala SS396
1970 Chevelle SS454
1972 El Camino SS350
1973 Chevelle SS350
2002 Trans Am WS6 Ram Air
67ss350camaro
« Reply #2 on: November 11, 2005, 12:43:44 PM »
We need to know more about your car to be able to determine if the engine is original to your car, but it probably is.
67 RS/SS 350 auto (owned since 81.)
97 V6 5-speed Coupe (work car ordered new)
2012 1LS (V6 6-speed) Coupe (new work car)
My Camaro
joemac8
« Reply #3 on: November 11, 2005, 01:31:02 PM »
What other information would you need to help determine if it is original?
