Author Topic: Rotisserie  (Read 19517 times)
DyRally-Z1986
Rotisserie
« on: September 23, 2013, 04:58:46 PM »
Does anyone have a rotisserie they are done with? I have been constantly checking Craigslist with no luck and looked on the internet and not sure of which one to exactly go with. Every manufacturer states theirs is better than the other. Let me know if anyone has any suggestions of has one they are done with.
Thanks Tommy
Re: Rotisserie
« Reply #1 on: September 23, 2013, 05:22:57 PM »
you could make your own, build what you need for your car, and practice up on the welding at the same time.. :)
elcamino72
    • More Information on Camaro Fraud
Re: Rotisserie
« Reply #2 on: September 23, 2013, 06:16:22 PM »
I have one by accessible systems in Tennessee, I love it.
http://www.accessiblesystems.com/
DyRally-Z1986
Re: Rotisserie
« Reply #3 on: September 23, 2013, 06:23:59 PM »
Which one did you purchase from accessible systems? Thats who I might go with if I cant find a used one.
Re: Rotisserie
« Reply #4 on: September 23, 2013, 06:46:59 PM »
Here's one for sale on Craig's List.. Nashville, TN area..  $600
http://nashville.craigslist.org/pts/3942713474.html
elcamino72
Re: Rotisserie
« Reply #5 on: September 24, 2013, 03:34:01 PM »
I have the Bottoms Up Lift 1500lb capacity car rotisserie with the pneumatic tire option.  The only change I would make would be to find a way to mount the rear of the vehicle solid instead of through the rubber in the rear spring mount.  I would probably make bushings out to aluminum to fit in there.
DyRally-Z1986
Re: Rotisserie
« Reply #6 on: September 24, 2013, 06:27:49 PM »
So you didn't mount to your tail pan?
elcamino72
Re: Rotisserie
« Reply #7 on: September 24, 2013, 08:25:58 PM »
BillOhio
    • photobucket
Re: Rotisserie
« Reply #8 on: September 25, 2013, 02:16:09 AM »
I used the same one with brackets and both seta of tires. Could take a john Deere gator and pull around the driveway. Worked fine.
1968 RS 327 4 speed
DyRally-Z1986
Re: Rotisserie
« Reply #9 on: September 25, 2013, 05:57:52 PM »
What did you guys do for the front? Attach to the subframe or firewall? And did you have to buy additional brackets for the front? Thanks for the help!
Re: Rotisserie
« Reply #10 on: September 25, 2013, 06:37:27 PM »
If you are going that far (rotisserie frame off), then you should remove the subframe for restoring independently which also reduces the load on your rotisserie support.   Attach to the same points on the body that the subframe attaches to, and the large nutserts at the top of the firewall (for the fenders)..
BillOhio
    • photobucket
Re: Rotisserie
« Reply #11 on: September 26, 2013, 03:28:28 AM »
I had subframe out
1968 RS 327 4 speed
BillOhio
    • photobucket
Re: Rotisserie
« Reply #12 on: September 26, 2013, 03:33:18 AM »
Front
1968 RS 327 4 speed
BillOhio
    • photobucket
Re: Rotisserie
« Reply #13 on: September 26, 2013, 03:34:43 AM »
My buddy Ron helped.me
1968 RS 327 4 speed
ggtsvnv
Re: Rotisserie
« Reply #14 on: September 26, 2013, 09:43:51 PM »
  I have been looking for one also. This is the one that I'm close to ordering but have not yet.
http://www.derekweaver.com/rodders-garage/auto-rotisserie/w-rotisserie/
It seems to come with a lot of extras and has good reviews.  Does anyone here have any experience with them? or know anything other than what the web site has on it?
