Author Topic: Chambered Pipe Vs. Regular Muffler Bracket hole for 1969 Z28?  (Read 6829 times)
llskis
Are the bolt holes(in the body) that holds the straps for the Chamber Pipe Muff. and the bolt holes for the regular muffler system in  the same identicle location? The location is
above the Transverse Muffler for both systems.  In both cases it holds staps(different) that bend downward and go behind the clamps on both systems. I hope I am
eplaining this correctly. Thanks-Larry
1969 Z28 Non-Radio and Jeriry MacNeish Certified
Steve Shauger
    • Vintage Certification
Re: Chambered Pipe Vs. Regular Muffler Bracket hole for 1969 Z28?
« Reply #1 on: July 12, 2013, 06:41:09 PM »
Yes body mounting locations and screws for the hangers are the same. The hangers above the axle are shorter/different..
Steve Shauger
llskis
« Reply #2 on: July 12, 2013, 09:15:44 PM »
Steve: Thanks Much. Larry
llskis
« Reply #3 on: July 22, 2013, 07:34:59 PM »
Just a followup with a question. Everything installed nicely. Looks/Sounds great. On observation looking at the muffler from the rear of car is looks very nice
and equal distance from the floor. (This is with the car on the floor; jackstands removed) But when I take a measurment with a ruler there is a 1/2" difference
from the floor. The driver side is closer to the floor then the passenger. The AIM does not give any specs on this. If anybody out there with a chamber pipe option
can you measure yours? Is mine within the limits? When I installed the new hanger on the driverside I used a floorjack to raise the system up. Comments Please!
Thanks in advance--Larry
« Reply #4 on: July 22, 2013, 08:00:11 PM »
your car itself may be 1/2" lower on the driver side....  it's not uncommon after years of having a single passenger (the driver).. :)
llskis
« Reply #5 on: July 22, 2013, 10:14:41 PM »
69Z28: Thanks for the response. Never thought of that; where would be a good accurate place to take that measurment on the car?
Thanks--Larry
dutch
  • Documented Canadian 1968 Z/28
« Reply #6 on: July 23, 2013, 12:14:39 AM »
If you have an AIM for '69 models I believe it probably give the road clearance specs near the front of it (I know the '68 version I have does)besides showing the measurement reference points as well..
Randy
« Reply #7 on: July 23, 2013, 04:32:14 AM »
There are measures for the front most and rear most of the lower rocker panel surfaces in the AIM as well..  I suspect that might be the best points for the body measures to get road height.
