Author Topic: 69 Z28 Carb accel linkage and vacuum hardline?  (Read 18416 times)
Re: 69 Z28 Carb accel linkage and vacuum hardline?
« Reply #15 on: May 01, 2013, 02:57:06 PM »
No, because when you place it in the clip and maintain it level the rise is to short. And if you try end remove bends and re-bend it will look re-bent, steel is not good bendable material. I will keep looking.
All of the fuel and brake lines are steel, and bend quite nicely if you use a tubing cutter and bender; go to your local auto parts store, get some 3/16" brake tubing, and bend it to suit your application.
DDZ28
« Reply #16 on: May 01, 2013, 03:28:43 PM »
Sounds like a solution, Thanks John
69 Z/28 Camaro LeMans Blue (Current Ground Up Restro)
68 SS Camaro L78 LeMans Blue (9977 Original Miles)(Next Ground Up Restro)
68 Z/28 RS Camaro Corvette Bronze (some where down the restro line)
68 Standard Camaro LeMans Blue (maybe a Resto Mod someday)
zman1969
Rich
69 RS/Z DZ302 Daytona bumble bee
69 T/A clone LS6/6sp
69 Nova SS 396
« Reply #18 on: May 01, 2013, 05:56:28 PM »
EVERYONE has the repop. Just get it from whoever is closest to you.
DDZ28
« Reply #19 on: May 01, 2013, 06:14:39 PM »
I have purchased the one from Heartbeat and it does not fit with the Z28 intake. I will make one. Measure the two and post it for info.
zman1969
« Reply #20 on: May 01, 2013, 07:13:26 PM »
well that saves me 25$ the only thing i cant make would be the crimps on one end i already have the intake clip so bending the tubing is no big deal thanks ahead DDZ28!
Rich
69 Nova SS 396
« Reply #21 on: May 01, 2013, 11:29:09 PM »
I have compared the repro to our original and it was the same and fits great. What bracket are you using to hold the steel vac. line?
DDZ28
« Reply #22 on: May 03, 2013, 04:27:08 AM »
Do you have a picture?
DDZ28
« Reply #23 on: May 08, 2013, 01:45:02 PM »
Here are 2 photos of the steel tubes I purchased and 1 that I made to fit.
