Author Topic: 69 camaro big block manual flywheel  (Read 5505 times)
jsg1010z
« on: January 11, 2013, 09:10:13 PM »
I have seen online references to xxx733 and xxx458N  for the correct flywheel numbers.  I searched the CRG database but could not confirm.  Thanks for your help. :)
Re: 69 camaro big block manual flywheel
« Reply #1 on: January 11, 2013, 09:38:14 PM »
The correct casting number is 3789733.
« Reply #2 on: January 11, 2013, 09:38:30 PM »
As per Jerry's "The Definitive 1969 Camaro Z28-SS396 Fact Book":
Quote
All manual transmission big blocks (except the ZL1) were equipped with an 11.00 inch cast iron flywheel (casting number, 3789733).
jsg1010z
« Reply #3 on: January 11, 2013, 10:05:37 PM »
Thank you!
« Reply #4 on: January 12, 2013, 03:43:52 PM »
That would be more correctly described as a 14" 168-tooth flywheel drilled for an 11" clutch.
