Author Topic: Temp sensor  (Read 43068 times)
rszmjt
Re: Temp sensor
« Reply #45 on: February 12, 2013, 04:20:22 AM »
I think the sender is Brass with Black plastic tower. I will take a digital picture of both and Email it to you as I am unsure how to post pictures on this site. The Car is Up on a Drive on hoist with a 67 Z28 underneath as well as other cars behind. It might take me a day or so as I have to climb up on a ladder.
Can you post a pic of your plastic connector?
Also, some say the sender was always brass, but others say some were not.  Which is yours?
What is the correct coolant temp sensor for 69 Camaro V-8 w/o gauge package. Pin or spade connector? Pictures? Thanks, Steve.
My 06A RSZ28 came with no consol and a center Fuel Guage, it has the Original GM assembly Line Installed Pin connector type sender ( like Ed Posted) and the plastic connector is off white.
lynnbilodeau
Re: Temp sensor
« Reply #46 on: February 12, 2013, 05:00:48 AM »
No problem.
Email me the best pics you can get.  I will crop and "dummy them down" enough to post here.
Thanks.
rszmjt
Re: Temp sensor
« Reply #47 on: February 12, 2013, 08:46:14 PM »
 Sender says AC-248 M...
rszmjt
Re: Temp sensor
« Reply #48 on: February 12, 2013, 08:47:50 PM »
Pretty sure it is Original, I have owned the car since 73
Re: Temp sensor
« Reply #49 on: February 12, 2013, 09:36:41 PM »
Mike, that's the correct assembly line sender for 69 V8's without gauges.
Re: Temp sensor
« Reply #50 on: February 13, 2013, 01:53:17 AM »
Just to get this straight since I have a 68.  Lynn do you need the temp connector with the push on pin end?
lynnbilodeau
Re: Temp sensor
« Reply #51 on: February 13, 2013, 05:02:33 AM »
Mike: Great pics.
And yes, I have a correct sending unit.  I need the temp connector for the push on pin.
tmodel66
Re: Temp sensor
« Reply #52 on: February 13, 2013, 07:24:33 PM »
Mike: Great pics.
Lynn Where did you find a sending unit? Can you get another?
Re: Temp sensor
« Reply #53 on: February 13, 2013, 10:11:21 PM »
I've got one.  I cut it off of mine and its a little close, but if the connector will come out of the plastic thing I think you could crimp it on.
lynnbilodeau
Re: Temp sensor
« Reply #54 on: February 16, 2013, 04:24:39 PM »
PM sent.  Would like to purchase it from you as is.
Lynn
lynnbilodeau
Re: Temp sensor
« Reply #55 on: February 17, 2013, 03:48:48 PM »
Sorry Daniel, but it is an old one that came on a head I purchased years ago.  Still works.  I have no idea if they are still available.
Mike: Great pics.
Re: Temp sensor
« Reply #56 on: April 11, 2015, 08:38:39 PM »
You can release the pin from the connector with a micro flat bladed screwdriver about .050 wide and .025 thick.
THIS WILL/SHOULD REQUIRE NO EFFORT!!
IF THE WIRE AND TERMINAL DO NOT SLIDE OUT EASILY YOU HAVE NOT RELEASED THE TERMINAL FROM THE PLASTIC CONNECTOR
A bobby pin (hair pin) works well if you pull the plastic coating off it.
This is for removal of PLASTIC CONNECTORS which have FEMALE BLADE receivers.
With the connector mates unplugged -
1.Take the wire from the rear and push it and thus the brass terminal end forward in the plastic connector,
2.Slide the screwdriver down the front of the plastic connector, there is a groove which the micro screw driver will slide into, in turn releasing the female side blade terminal.
3. With screwdriver still in slide the terminal and wire out the back. Males sides are a different procedure.
As noted the reproduction temp sending unit plug is correct however the plastic connector is black VS white.
