Author Topic: Console/Gauges VIN Decode  (Read 5194 times)
upscope757
  • Almost there...
« on: October 07, 2012, 11:31:36 AM »
I have seen conflicting guidance out there on the console versus console/tach & gauges in the trim tag decode.  Is there anything different in the cowl tag regarding these two options?  Any hard connection between gauges on an SS with respect to 4spd or Powerglide?
Matt: 1967 RS/SS - L48/Powerglide - Sierra Fawn/Beige Vinyl Top, Charleston, SC
tmodel66
Re: Console/Gauges VIN Decode
« Reply #1 on: October 07, 2012, 01:52:30 PM »
No and No to both. Trim tag tells the color and standard or custom but nothing about D55 console or U17 gauge package. You could get U17 on any car with console regardless of transmission.
Read more about all the options from this link:       http://www.camaros.org/pdf/options.pdf
Daniel
« Reply #2 on: October 07, 2012, 02:43:45 PM »
In 67, the tag only tells if equipped with a console.
U17 was available on any V8.
Gotta look at the wiring to tell if it had gauges originally.
TRLAND
« Reply #3 on: January 14, 2014, 10:21:22 PM »
An old post I know, but this is the exact mystery I'm trying to solve.  My firewall has no hole for the oil line gauge but the trim tag indicates console and I have a low fuel light at the speedometer.  What exactly about the wiring should I look for to determine if gauges were original?  Yellow low fuel sending wire or something else?  Also is there any precedence for an early February '67 car (327 automatic with AC) to have the oil pressure line routed through the grommet in the corner of the firewall behind the power brake booster? Could this be an anomaly chalked up to human error or corner cutting?  Again, there is no hole in the firewall where it should be, just a dimple.  There's a 1/8" hole low on the firewall behind the distributor.  I've read what I could find here and at TC about the grommet vs. brass fitting and when that was changed over and this car is squarely in the midst of that time period but nothing I read clears this up.
Mike in Northern Illinois
1967 RS 327
