Fastener Needing Identification
Started by COPOZ/28, July 29, 2026, 07:33:44 PM
COPOZ/28
I found this one, loose, hex head screw wedged between the upper rounded edge of the washer reservoir and the  radiator closure panel on my '69 Z28.  It's 1/4"-20, non-full thread, 7/16" hex head, 13/16" long with a small hole drilled through each flat on the hex and a larger dia. blind hole, about 1/8" deep, in the center of the head.  Anyone recognize it as a legit Camaro fastener?
At first blush, it resembles the two fasteners that attach the left side radiator support to the radiator closure panel, into well-nuts, but the those screws have a flange head and do not have their hex flats thru-drilled, per the AMK website -- unless I'm wrong about that.
Thanks for the help.
Chuck B.
Ice cream run in our unrestored '69 Z/28 on Woodward Ave. in Royal Oak, MI.
Daytona Yellow, NOR 05E, Born on June 2, w/X33, M22 and 4.88 'BX' Axle via COPO 9511CB.
(Need Speedo Adapter p/n 6476736 - 0.777 ratio.  Have 6476735 - 0.824 ratio and 1565215 - 0.950 ratio to trade)
I don't think that's an original assembly line fastener.
