1969 RS headlight doors will not fully close
Started by hdptsr, May 25, 2026, 08:35:21 PM
hdptsr
Hello,
Everything is new (vacuum) and my headlight doors do not fully close, how to I adjust that?  They will close if not connected to the rod of the Actuator.  I have the vacuum cans all the way back but I am still need about 3/4" more to get both doors fully closed.  It seems like the rod of the actuator is too long?  Is there any adjustment?
Thanks for any help you can give! - Joe
Joe
hdptsr
here are some pics, the right passenger is fine, it is the drivers side that is about 1/2 inch from closing.  The actuator is all the way pushed in.  Cant find any more adjustment for it.  I did scoot the canister as far back as I could on the bracket.
Joe
KevinW
Nice Pace!
With the actuator disconnected, does it close fully?  The factory put body shims between the rad support and headlight bracket (under the bolts) to adjust it.  I have not personally worked on this, just something I discovered long ago.
x66 714
Is the hinge on the cover stopping it from closing? If not, loosen the bolts of the actuator pivot & close it by hand. Tighten the 2 pivot bolts. Try that.....Joe
hdptsr
I have shimmed it at the radiator core support, I have loosened the bolts and closed it as far as I could and re tightened them.  It will close all the way if the actuator is disconnected.  It is like the actuator rod is too long?
Joe
169INDY
My Z11 has this EXACT same problem.- Dang it.
As a side note: I was reading Z22/B3 & I never knew we are suppose to Glue [18] the chrome Slit RS headlight grill [12] to the Door [13] !
I may have just found a very annoying source rattle when driving?
68 SS/RS L35 Th-400 LOS
69 Pace Car L48 Th-350 LOS
68 Z28 M21 LOS
hdptsr
I ordered a new bracket and different canister to see if that will fix it.  I have read that some people actually shorten the rod of the canister and reattach the clevis pin ring.  I have also read that the rear bracket can be modified.  I hope I do not have to do this!  We will see!  Thanks for the info and discussion!
Joe
