Clutch pedal switch on steering column
Started by marriest, February 23, 2026, 03:36:27 PM
marriest
Is there any info on the Clutch pedal switch on steering column?
Part of starter system with 2 purple wires. I guess it keeps you from starting car in gear.
My car will not start and I am wondering if there is an issue with this switch.
Where is it and how do you get to it?
Terry Marries 126479N641885
Terry
boomer632
Please define "will not start" If the part is working correctly, no power reaches the starter if clutch is not depressed. Ive never really heard of that part failing. Make sure the linkage is connected to clutch pedal lever. Follow purple wire.. cant miss it.
06A X66 711 57 57 M22 BU
marriest
Turn the key and nothing happens. No click nothing.
Terry
x66 714
You could bypass the switch by connecting the 2 purple wires together. Make sure it's out of gear with parking brake on. If the switch is the problem, the car will start.....Joe
David K
What pdeal setup and transmission does your car have?
marriest
My car still has the machinal linkage from the transmission to the steering column.
To start the car it has to be in reverse with the clutch in.
The two purple wires are on top of steering column next to the firewall.
This issue started at a car show where someone recommend tapping the starter and low
and behold it started. So I assumed solenoid I replaced but still dead. Bench tested
starter worked fine. At a loss for where to look next.
Terry
Terry
GMAD_Van Nuys
The link below shows the location of the clutch pedal switch and also a source for a replacement switch:
https://www.camaros.net/threads/how-do-you-replace-the-neutral-safety-switch-in-a-69-camaro.487969/
I had a similar problem with my 1979 Trans Am and I replaced the clutch pedal switch, then replaced the ignition switch in the steering column, followed by installing a new Delco solenoid.  The car still would sometimes not start and the problem was solved when I bought a new battery.  Even though I kept the battery charged, it apparently didn't have enough amperage to engage the starter.  I also checked the battery cables and ground wires and they were okay before I started to replace parts.  Good luck as electrical problems are no fun! - Mark
MO
Quote from: GMAD_Van Nuys on February 28, 2026, 01:47:57 PMThe link below shows the location of the clutch pedal switch and also a source for a replacement switch:
Good info! I had a Camaro and a Corvette with the same issue. Tried a few fixes and never nailed it down. Wish I had know about possible battery issues then. I didn't learn that lesson until after I no longer owned either of the cars.
169INDY
1969 Chevrolet Service Manual
ENGINE-ELECTRICAL (6Y-32)
Starting Motor and SOLENOID CHECK
ENGINE-BODY & CHASSIS (12-17/18)
Clutch Operated Neutral Start Switch (FIG 30)
1969 Factory Assembly Manual
WIRING DIAGRAM- Fuse Panel
UPC 12 / D2
"Switch" (Clutch Pedal Operated)
"WHY" Can I NOT find the Floor Shift Manual - Safety Switch adjustment or setting in the 69 AIM
Ideas>?
68 SS/RS L35 Th-400 LOS
69 Pace Car L48 Th-350 LOS
68 Z28 M21 LOS
Start with the starter wiring. When you turn the key, you should see 12 volts at the solenoid.
