Clutch pedal switch on steering column
Started by marriest, February 23, 2026, 03:36:27 PM
marriest
Is there any info on the Clutch pedal switch on steering column?
Part of starter system with 2 purple wires. I guess it keeps you from starting car in gear.
My car will not start and I am wondering if there is an issue with this switch.
Where is it and how do you get to it?
Terry Marries 126479N641885
Terry
boomer632
Please define "will not start" If the part is working correctly, no power reaches the starter if clutch is not depressed. Ive never really heard of that part failing. Make sure the linkage is connected to clutch pedal lever. Follow purple wire.. cant miss it.
06A X66 711 57 57 M22 BU
marriest
Turn the key and nothing happens. No click nothing.
Terry
x66 714
You could bypass the switch by connecting the 2 purple wires together. Make sure it's out of gear with parking brake on. If the switch is the problem, the car will start.....Joe
David K
What pdeal setup and transmission does your car have?
marriest
My car still has the machinal linkage from the transmission to the steering column.
To start the car it has to be in reverse with the clutch in.
The two purple wires are on top of steering column next to the firewall.
This issue started at a car show where someone recommend tapping the starter and low
and behold it started. So I assumed solenoid I replaced but still dead. Bench tested
starter worked fine. At a loss for where to look next.
Terry
Terry
