Main Menu
Wire end
Started by BillOhio, June 30, 2025, 03:35:37 PM
Previous topic - Next topic
BillOhio
I am working on a January 1969 Z, and I found this plug-in out of the wiring harness near the horn relay. My other Z does not have this. This harness could be tampered with so maybe it belongs somewhere else and that's just where it ended up. It's sort of looks like the one on the brake block, but it is there.
1969 Z28s, Burgundy and Rally Green
1968 RS 327 4 speed
1970 Z28 M22 4:10
1969 RS legend certified
What color is the wire?
WaltZ
could possibly be half of an inline fuse connector. see if a fuse fits in it.
if it does, then look to see if hood had a light.
not sure why it would have been in the harness though.
just thinking out loud here.
curious to know what it turns out to be
BillOhio
Wire is black.  I wondered about a fuse holder also. Then that odd clip on the wire
1968 RS 327 4 speed
1970 Z28 M22 4:10
I will ask someone that might know.
WaltZ
if this wire is separate and not wrapped in the harness, then most likely the hood light.
the clip would attach to the fender lip support.
this female end would attach to the red on the horn relay
then there would be a male end that that went to the light.
horn relay to female, then fuse, then male end which connects to under hood light
depending on the installer, there could be 1 or 2 clips on the fender, one on each side of the fuse.
assembly instructions: U26 A1
BillOhio
Thank you.  I will look that up.  The car now has a cowl hood so the light could be missing.
1968 RS 327 4 speed
1970 Z28 M22 4:10
BillOhio
I am pretty sure it is for a light.  Found some on ebay and wire and clip the same.  Probably unhooked when someone put a silly cowl hood on this car!  Thanks guys
1968 RS 327 4 speed
1970 Z28 M22 4:10
