Main Menu
possible to fix fender front corner?
Started by Tom Feramenti, January 15, 2024, 10:10:26 AM
Previous topic - Next topic
Tom Feramenti
After I sanded the putty, some old damage came out. Apparently there is no repair panel on the market for this area. Has anyone ever repaired this area?
x66 714
There are people that could metal finish that fender......Joe
Tom which car is that on?
I used to have an extra fender that was rusted in other areas that I *think* I MIGHT still have.
If I have it and it's good, I might be able to cut out a piece for you. Let me see. It may have been put in the scrap pile and might already be gone. The problem is the scrap pile is mostly buried in a 2 to 5 foot snow drift.
Tom Feramenti
thanks for the quick reactions! :D
I can tin the fender, but then it won't have the correct inner radius to the headlight.
The fender is rust free, too good to throw away.
Bryon, this is a '68 RS, but the standard fender would also help me if I... If I wasn't 16h away I would come help you with the snow :-)
Tom Feramenti
Here is the progress. I got a metal patch from a standard fender. I was able to adjust it so that it now fits in my RS fender
Make sure the fender does not have droop after all the front sheetmetal is bolted up tightly. Many cars have droop that never gets fixed. Cars do not leave my shop with this unsightly issue.
 Tom,
    What method of welding did you use?
FRANKTHECRANK
Looks like MIG welding to me,......nice job.
Tom Feramenti
Thank you guys, yes i have weldet with mig. @ Sauron327 do you mean when the subframe bushings sag? do you have a picture of a drooped Fender?
