Fuel Pump Research
Started by x66 714, August 29, 2022, 05:07:28 PM
x66 714
David K
x66 714
Yes. March 1969. What is 40616? I don't have that for a 1st gen Camaro....Joe
David K
x66 714
Finally found another 40727. It has a "KI" date which is Nov 1969. Most likely not correct for a Camaro. Owner said it was his original for his 1/70 LS6 Chevelle. It's another known date....Joe
David K
Sometimes they just don't last....20 years.
1cuda
Original fuel pump from an April 4th assembled Tonawanda 327
x66 714
Thank you 1cuda. So it's T0404? That's a date I didn't have. Joe
1cuda
No problem Joe...a very original engine still has it's original distributor cap and rotor...fan belt... heater hoses etc...a wealth of information.
All the best Frank
David K
Cuda, what's with the funky stamped numbers?
Quote from: David K on June 17, 2023, 11:35:09 AM
It is not a US installed engine, it is from a 1968 Australian Holden.
See this thread.
http://www.camaros.org/forum/index.php?topic=20741.msg188739#msg188739
Updated the sheet, adding the parts book listings.
boomer632
Reviving old thread.. On a 06A Camaro 396 right now. pump has the large AC on both sides of housing. CM40727 doesnt seem to line up with the table Kurt posted on CRG. Any input would be appreciated.
06A X66 711 57 57 M22 BU
1cuda
Quote from: David K on June 17, 2023, 11:35:09 AMCuda, what's with the funky stamped numbers?
Thanks to bcmiller for answering your question...yes it's from an early build date Holden here in Australia.
x66 714
Quote from: boomer632 on November 22, 2025, 10:48:11 AMReviving old thread.. On a 06A Camaro 396 right now. pump has the large AC on both sides of housing. CM40727 doesnt seem to line up with the table Kurt posted on CRG. Any input would be appreciated.
The "C" would be March. The "M" would be 1973....Joe
