Main Menu
1968 Camaro fender help!!
Started by confern, June 02, 2026, 10:31:48 PM
Previous topic - Next topic
confern
I have a 1968 camaro standard fender I'm trying to see if it is anything that would be original. I know it's not an assembly line fender, but trying to see if it may or may not be a GM reproduction. The guy I got it from said he had it stored away for over 20 years. In the first image near where the fender bolts to the firewall, there is a 04 09 stamped into the metal there. Nothing else, and the sticker that has been gone for some time but can see the shape of the sticker at least. Help please!!
David K
Show the captured nuts on the fender. Originals can usually be identified.
Bryon / 1968 Camaro SS 396 coupe - now 468   /  1967 Camaro RS/SS 396 coupe L35/M40 - project / 1970 Nova updated L88 M40
confern
I believe it does not look original compared to my assembly line fender.
confern
Quote from: bcmiller on June 04, 2026, 08:41:17 AMShow the captured nuts on the fender. Originals can usually be identified.
Loaded a couple photos.
I don't have any loose fenders here to take pics of to compare, but show the nut side. The originals will have square nuts.
Quote from: confern on June 04, 2026, 04:12:49 PMI believe it does not look original compared to my assembly line fender.
That pierce nut is not square like my assembly line fenders. Yours is domed and has staked corners which is typical of repro nuts. The NOS fenders I've had also had correct pierce nuts.
