Trouble shooting cig lighter
Started by sixt9x33rs, February 17, 2014, 08:29:55 PM
sixt9x33rs
The cig lighter on my Silver Z does not work. I have 12 volts on the flange inside the cylinder of the lighter. My lighter works, tested it in the Gold car. I am guessing when you push the lighter in for it to heat the flange in the cylinder slides in the lighter and the circuit has ground somewhere for the lighter to heat? I cleaned up the lighter with a Dremel, cleaned up the the cylinder with a Dremel. Still nothing. Any ideas?
Lawrence
The lighter housing grounds through the ashtray; the lighter center terminal has power all the time, and when you push in the lighter, current flows from that center terminal through the lighter heating element to the lighter housing to ground.
sixt9x33rs
Thanks John. Would it be possible that the housing is just not making good ground to the ash tray. A simple twist or turn may help?
Lawrence
Quote from: sixt9x33rs on February 18, 2014, 05:04:56 PM
Lawrence
Could be - the inner housing grounds to the ashtray at its lip at the front, and the outer housing grounds to the ashtray at its serrated flange on the back side of the ashtray panel. Make sure the outer housing is "cutting paint" on the back of the panel.
sixt9x33rs
Quote from: JohnZ on February 19, 2014, 10:49:25 AM
Lawrence
Thanks John will check it out.
sixt9x33rs
I figured it out. It was just rusty and not making a good connection.
Quote from: sixt9x33rs on March 23, 2014, 10:34:18 AM
Man, Lawrence, that's good to know because when I read topic, I thought you were having trouble shooting your cig lighter, which I was going to suggest taking better aim, a pistol rest, and suggest the correct ammo. Also was worried about shooting inside a vehicle and the dangers with ricochet. Wheww! that is a relief...and about a week early for April Fool's day, but a primer nonetheless. hope you guys get a laugh.
Quote
Man, Lawrence, that's good to know because when I read topic, I thought you were having trouble shooting your cig lighter, which I was going to suggest taking better aim, a pistol rest, and suggest the correct ammo.....
Oh, don't do that! The liberals will want to pass yet more gun control laws to add the the thousands already on the books.  :D
sixt9x33rs
Quote from: ko-lek-tor on March 23, 2014, 03:39:12 PM
Got a good laugh!!
