Yes... my first V8 rebuild ;-)
Started by Danishbanker, June 26, 2013, 04:52:55 AM
Danishbanker
Hi.
YES... IT lookes like I did it. My first ever complete 327 V8 rebuild ;-)
I must admit I have had butterflies in the stumag for a few weeks now, and yeasterday after I had been checking everything over and over again I turned the key - and wromm wromm..
I ran it over 2000 RPM for about 20-22 minuts in different RPM.
I put the timing on 8 degrees to begin with, disconected the vacum to the distributor ( original with points )
Then turned the RPM up til 4000 and the timing was 42 degrees.
My book says timing at 4000 should be around 34-38 isn“t that right??
What should my idle RPM be?
How much should it drop when put in gear?
How much should my idle timing be?
I put in a bottle of came brake in doze in the oil - when should I change the oil ? ( the cylinder was only honed and new rings )
Thanks for your input ;-)
Regards
Claus, Denmark
* 55 Chevy Bel Air
* 67 Camaro RS
* Harley Fatboy
www.bankmand.com
jvb6648
Hi Claus, we'll need to know the horse power, carburetor and if it a manual or standard transmission. Timing can be 2 btdc,4 btdc or tdc and idle can be 600,700 or 750.. Jim
68 Z/28
Danishbanker
Pretty much std 327.
Has the sum1102 cam, 600 Holley, powerglide tranny
* 55 Chevy Bel Air
* 67 Camaro RS
* Harley Fatboy
www.bankmand.com
