Telescoping Antenna
Started by lakeholme, June 11, 2013, 10:44:15 AM
lakeholme
http://www.camaros.org/forum/index.php?topic=10918.0;all
So, did the telescoping antenna fully extend to a height of 30 inches?
Did it have the same ball tip/
Does anyone have a picture?
Steve Shauger
On AM you adjust the antenna height so that you tune the RF circuit. This helps optimize reception for the mixer-oscillator stage. Since the FM antenna is fixed height, you optimize/tune the am signal with a trimming pot on the radio itself. Usually there is a label noting "trimming pot" with an access hole located on the radio case.
Steve Shauger
The AM telescoping antenna isn't round - it's an aerodynamic shape, like a wing, including the tip; fully extended it's 46" long, and collapsed it's 18" long. Photo below.
lakeholme
Thanks, John! That's exactly what I was trying to confirm.
Steve Shauger
Yes the AM antenna mast is elliptical. Just a note, I've seen original cars come with the tip lined and without a line. There was discussion that the replacement antennas did not have the line on the tip, but believe they came both ways.  The attached pic shows 3 old antennas I collected over the years with plenty of patina. The middle one has the lined tip.
Steve Shauger
lakeholme
Paceme, thanks for the pic.
So was the base the same for both fixed and telescoping?
Steve Shauger
Steve Shauger
Rick68
I have an antenna I bought years ago that is oval/elliptical shaped except for the very last section that extends.That part is round with a ball tip.Someone told me that it is off a Pontiac Firebird or is it a service replacement or an aftermarket antenna?
Quote from: paceme on June 11, 2013, 07:20:44 PM
I tend to agree with that - the AM antenna that came with my car appears to be the original (like virtually everything else is), and it doesn't have the little line in the tip.
My original is lined, as are the 4 examples of NOS adjustable masts in the pics that follow. 3 are '69's, 1 is a '68, and the 5th mast (at the top, barely visible) is an NOS AM/FM. The '68 mast is exactly .375" shorter in overall length, plus the mount is threaded rather than a splined fit.
These are/were in original GM packaging purchased from GM dealers - 100% positive they are NOS GM.
'69's are 19.375 OAL, '68 is 19.00" OAL. AM/FM fixed mast is 31.500 OAL.
1967RS/SS
Don't know if my antenna is original to my 67 but here are a couple pics of my AM rear antenna tip and base
1967 RS/SS L-48
Van Nuys 01C
Joseph
lakeholme
I'd be interested in knowing if 1967RS/SS's tip is a replacement or original? I've seen several of those "screw tips" on a variety of cars.
QuoteI'd be interested in knowing if 1967RS/SS's tip is a replacement or original? I've seen several of those "screw tips" on a variety of cars.
That's an aftermarket antenna.
lakeholme
Thanks, Ed. Do you know any details?
I'm not sure what you mean by details Phil.
