0 rocker arms BIG or small 0 ? differences?
Started by zman1969, April 24, 2013, 08:50:21 AM
zman1969
I just bought a set of 0 rockers for my 302 and a few of them have a different style 0 some large and some small - I was wondering what the difference was if any?
Rich
69 RS/Z DZ302 Daytona bumble bee
69 T/A clone LS6/6sp
69 Nova SS 396
69Z28
From what I have read recently the big O were fefore 69 and the small O was 69 and after. As for material differences I don't believe there are any.
Quote from: zman1969 on April 24, 2013, 08:50:21 AM
GaryC
zman1969
Rich
69 Nova SS 396
69Z28
I found where I read it. If you have Jerry M's revised 4th edition Definitive book on page 26 there is a pic of both versions of the 'O'. It says research shows the 67 Z28 had the larger 'O' than the 68 and the 69.
GaryC
Chevrolet used 240,000 stamped rocker arms EVERY DAY; it's highly unlikely that there was only one supplier or one set of precision progressive-die tooling.
69Z28
At least that explains why I have a few rockers with the 'O' horizontal, vertical, small and large. Wow. Can I assume they were mixed this way on a given engine?
Quote from: JohnZ on May 01, 2013, 09:48:51 AM
GaryC
x77-69z28
Umm, let's see some O's.....
70 Z/28
72 LT1
11A 69Z small O sideways
Mixture of O's
tmodel66
Has anybody ever saw an O with a line thru it? I've got a set in a box in my shop. I replaced them with Crane's cause they are in a Crane box. I can't remember what they were for though.
Daniel
69Z28
Exactly what I have too.
Quote from: 68camaroz28 on May 01, 2013, 09:35:12 PM
70 Z/28
72 LT1
Mixture of O's
GaryC
canadair
the rockers with the triangle are they also high performance rocker arms ?
69Z28
Honestly,don't really know anything about them. Mostly installed on low performance engines. Just a guess though but probably didn't get a process that the 'O' rockers received.
GaryC
jdv69z
Here's my original set.
Jimmy V.
69Z28
Just out of curiosity, I have heard it's best to keep the same pivot ball to the same rocker. Are there any exceptions or is it a must to get new pivots? Mine are all mixed up in a box, all look fine with no blueing, cracks, galling or score marks. I'm using roller tip stamped steel 1.5's at the moment and probably will continue using them when I finally pull the 350 and install the 302, but what if I did go back to the 'O' rockers?
GaryC
