3 Speed Auto Steering Column to 4 Speed on the floor Question
Started by 69Z28freak, March 11, 2013, 10:41:54 PM
69Z28freak
I am changing from a 3 speed auto on the column to a 4 speed on the floor and I am wondering if I can still use my steering column. Obviously I need to remove the shifter handle. However, what other changes do I need to make. Or would it be easier/make more sense to buy another unit. If using my existing is inexpensive and an easy swap, I would prefer to go that route.
Mike 1969 Grandma Camaro
In my opinion, I would pull the original column out and keep it intact, put a donor column in, or upgrade (which is really the best case) to a tilt column. You can pick up a non-tilt one for a floor shift fairly inexpensively, just takes patience and looking. I know a tilt column is pricey, but in my case, this old body just doesn't seem to slide so easily behind the wheel of the old Huggers any more.
Depends also on how original you want the look to be - your linkage is going to change, depending on if you use a factory style Hurst reverse lock out. Bellcrank may work, but you'll have to look up the parts to decide the differences. Shouldn't be terribly difficult -
P.S. Check out eBay auction #321088117709 - Canadian, but looks pretty decent, good price so far, no bids. Good luck -
( I should qualify the Canadian statement before I catch heck - I only meant North of the Border for shipping considerations !)
69Z28freak
Quote from: z28z11 on March 14, 2013, 11:34:45 PM
Thanks Steve, great suggestions. I will check that ebay listing out.
