Penske 21015 dwell?
Started by Mike S, February 19, 2013, 07:27:00 PM
 Picked up a Sears-Penske 21015 dwell/tach meter today and installed a new 4.5v battery.
I have no manual unfortunately. I'm trying to figure out how to calibrate the 'set line' setting but can't get the meter to move.
I verified the meter is working.
I assume this is for the points resistance measurements.
Does anyone happen to have this model by chance?
MO
I have a manual for a 21019 if you think that will help.
Everett#2390
Put the two leads together to get full scale deflection, then adjust for zero.
Meter ready for use.
A flashlight is a case for dead batteries.
 I was able to get it working last night. It's been a while since I had to take out the DVM and troubleshoot a point to point wiring circuit (did that in the 70's when I repaired TV's back then) and it turned out to be a cold solder joint. A little sweating of the joint and presto...it worked. I can now get the zero set to function.
Nothing like seeing 'Made in the USA' label on something this old and still working.
Thank you for the replies!
<<Nothing like seeing 'Made in the USA' label on something this old and still working.>>
My (J.C. Penney) dwell/tach meter is over 40 years old, solid chrome-plated die-cast housing, glass meter lens (not plastic), and still works great; they don't make them like this any more.  :-)
