68 z smog system
Started by 427-KING, September 27, 2012, 01:16:07 PM
427-KING
I have access to the vin,ill see what it is and post it...
427-KING
427-KING
Built 1st day July according to the crg date  vs vin chart.
1968 Z28
Mine is 475xxx.  Three weeks or more with the wrong pulley???   Don't know if they ran out of the 522 or some yo-yo put on the first pulley he grabbed.
Jerry G.
Z28-1968-07C-Norwood
2nd. Owner, 38,000 miles
HOT3O2
King,
What are the date codes on the Wittek hose clamps on your pump?
Thanks, Rick
Rick
69 RS/Z28
427-KING
10B 68 Z with original shallow smog pulley.
I've seen others.
427-KING
I've seen others.........   The pulley does not have #116 on it, it is blank, it was on "backwards",and I looked on both sides.
1968 Z28
Quote from: 427-KING on September 30, 2012, 11:50:29 PM
Never seen one blank..that is unusual.....my pulley does have the number #3927116 stamped on it.
By "backwards" do you mean the smooth side toward the pump...that seems to be what it appears in the photos.  Although the AIM states that the part number faces the pump, my original pulley had the part number facing toward the front and the smooth side facing the pump.
On my #116 pulley, there is a difference in diameter between the two sides.  The smooth side of the pulley has a slightly smaller diameter than the part number side.  Also there is about a 1/8" offset from centerline between the two sides.  Is this the same on your pulley?
Jerry G.
Oh, you thought he was trying to sell it? =)
427-KING
#27
If you take a supply and demand class youll see that whenever you have items no one else has, you can ask whatever you want,and will eventually get it.  Last time i checked with the outfit everyone refers people to on this site they wanted 5500.00 ,but didnt have it in stock.......... So you can pay me 3850 direct, or buy mine for 5500 thru them. I suspect the 5500 route is less painful for some.
generally speaking, I would agree. I just prefer to sell items in my lifetime.
In my opinion, ebay is the pinnacle of supply and demand. List something on there that's rare with a $1.00 starting bid and NO reserve and after 7 days you'll find out exactly what the demand is!
