a few questions about my 1967 rs ss
Started by 1967heaven, July 31, 2011, 10:27:48 PM
1967heaven
i just bought a 1967 RS/SS today all numbers match engine trans except rearend which i was given two nova 12bolt rearends
it has new NOS front fenders core support inner fenders all window molding inside and out rocker molding, some pieces i have 2's and 3's of
car has 32,875 miles on the odemeter which is 3398 more miles than its last registration in 1986 it has been sitting since 1988 when it was disassembled
to be turned into a drag car (never finsihed) so i have a fairly decent restoration project with alot of new NOS parts all of which still have GM tags and stickers on them
the only thing that really has me puzzled is the color of the block it is blue underneath decades of grease and oil like i had said all numbers match except the rearend
even all the accessories like the alt, carb and the air pump have the proper date codes anyone have any more info on the correct engine paint code?
i would think orange like every other small block ive seen but then again ibe been wrong before  ;D   any help or advice would be awesome
VIN124377L135720
ENGINE SUFFIX V0113MT
also it has chrome chevrolet script valve covers?   must be aftermarket or chromed later?
Quote from: 1967heaven on July 31, 2011, 10:27:48 PMthe only thing that really has me puzzled is the color of the block it is blue underneath decades of grease and oil like i had said all numbers match except the rearend
The original engine would have been painted orange.
x77-69z28
THE SS-350 CAME WITH CHROME CHEVROLET VALVE COVERS. SAME COLOR AS MY 67 RS/SS
vtfb68
Check the casting date of the block, it should be before Jan 13th 1967. What is the build date of the car? it should be after Jan 13th. A good picture of your engine pad and trim tag would be the best way to get the best info here. Good luck.
   VT
68 08E LA RS Y2 749 L30 M35
x77-69z28
so butternut yellow is not the orig color?
1967heaven
no that is 24yr old primer it was stripped down and put into storage in late 1986
color was ermine white code cc
68Zproject
68Z28
67 RS Ragtop
Nice project. I noticed you have no holes below the rear bumper for backup lamps, maybe someone changed out the taillight panel and forgot the holes?? I also own one with "wings", and when I had the block hot tanked prior to rebuilding I noticed quite a few areas were blue (under the chevrolet orange). The machine shop stated he see's quite a lot of blue on the old original blocks (again under the orange), and the paint is really tough as it doesn't come off in the tank, while all the other paint does.
1967heaven
WOW  thanks for pointing that out i really didnt notice.    its going to thr media blaster on friday so we shall see whats under the 25 year old primer
67 RS Ragtop
Just another question before you invest further $$$$. Did you verify the hidden vin numbers vs the other numbers on the car?? The taillight panel, open rivet at the trim tag, along with the engine color, made me "curious". Best of luck.
1967RS/SS
1967heaven,
Your car was built close to mine!  My LA 67 RS/SS 350 has a build date of 01C as well and a production number of 14116 (only 4723 before yours).  Pretty cool!
1967 RS/SS L-48
Van Nuys 01C
Joseph
