Parking Brake Switch Installation
Started by Oregonjam, June 20, 2009, 11:02:23 AM
Oregonjam
Does anyone know how the parking brake pedal switch was setup? ???
What should contact the switch?
Should the switch be depressed when the brake is engaged or dis-engaged?
I recently removed the parking brake to restore the kick panel. When it was reinstalled, I cleaned the contacts for the switch and since then the light is on all the time. It appears that something should be contacting the switch but nothing comes close to it. I have looked in the AIM on page 5-C1 (page 74) and it is not depicted there.
I have been looking at a number of 67 through 69 Camaros to compare and they are all run the same which appear incorrect. The pic shows how the switch is setup in my 68 when the brake is not engaged.
Any help is appreciated.
68 07D SS350
John
Sauron327
Your're missing the tab that contacts the switch.
Oregonjam
Quote from: Sauron327 on June 20, 2009, 01:39:18 PM
Is this a separate part or a return on the pedal arm sheetmetal?
Does anyone have a photo they can share of this?
Thanks again.
68 07D SS350
John
Sauron327
Rick's part # SW-36. Faster than crawling under my dash.
Oregonjam
Great. Thanks, I was not sure what I was looking for. This part must be commonly misplaced as I have looked at many Camaros and none were complete that I saw.
68 07D SS350
John
Oregonjam
Was the switch tab spot welded, rivoted or simply clipped on?
Thanks Again,
John
68 07D SS350
John
Grsmnkey
Hi,
It clips on, not the best picture...
Pex68
The cable holds it in place and there is a clip that keeps the cable in.  When the brake is disengaged the tab depresses the switch breaking contact to ground interrupting the circuit and turning off the light.
Chris P
SMoon67
Would someone please post a picture of this clip showing how it looks installed?  I can't really tell from the AIM.  Thanks.
67 RS/SS 350 4 spd Marina Blue
1988 IROC-Z Convertible
1957 Chevy Belair
1940 Chevy Cabover
<<Would someone please post a picture of this clip showing how it looks installed?  I can't really tell from the AIM.  Thanks.>>
Here's a photo that shows the cable and the clip.
SMoon67
1957 Chevy Belair
1940 Chevy Cabover
