Original 67-69 Camaro driveshafts - information requested about your car
Started by bcmiller, March 16, 2011, 12:12:18 PM
Charley
68 SS RS 396 325 hp T-400, 02Ecar, PP on axle tube. 50" on driveshaft, straps and bolts, ujoints inline, injection molded in ujoints, Los car
www.1970Z28Camaro.com
www.MCACN.com
Thanks Charley.  Those stripes are very interesting.
Do you know of any original 67 or 68 cars with a big block and a manual transmission that we can check the driveshafts on? I believe they are not they same length as other 67s and 68s.
Kurt and Ed, I think we might be getting close to having enough information to feel comfortable posting those numbers.
Any more 67 or 68 big block manual transmission cars out there?
canadair
1969 Z28 driveshaft was nothing special.  1969 AMA information says all Camaro driveshafts were 49.56 inches long.  Still working on fine tuning the details.
OG69Z
Hi, I have an original 23,000 mile 69 Z/28. My particular driveshaft has a part number stenciled on it. I don't see any others on this thread with anything similar, other than what Bertfam posted.  The car is a Los Angeles build, 03B, 302 with M21.  Photos:
I hope this will be some help in your research. I look forward to participating in this forum.
Bob
Bob,
WOW, that is awesome.  With that stenciled on there I would think there should be some stripes too.
Did you check the length from the center of 1 u joint to the center of the other?
That's a Service replacement prop shaft, used for all except TH400 - they were furnished without the yoke and U-joints (unlike the production prop shaft assembly, which included the yoke and U-joints).
69z28rsbilly
Were the 67 to 69 Firebird drive shafts the same as the 67 to 69 Camaros ?
X33 72 72 RS
X33 71 71 RS
X33 10 10
Quote from: 69z28rsbilly on July 28, 2011, 03:21:30 PM
Part numbers were different.  Length apparently for Firebirds 67-69 was 49.96 for all except TH400 cars which were 49.30 inches.  Stripes apparently different than Camaro.
69z28rsbilly
were the yokes the same ? Will the drive shafts interchange ?
X33 72 72 RS
X33 71 71 RS
X33 10 10
erikjohn
1967 RS/SS GG/Blk Int - 4sp - Posi - CC - IC - PBR - #Mtch w/POP & Dlr Ship & Wty Info
Well it depends.  What year and what application driveshaft are you talking about?  TH400 yoke is different than others.  All 69 Camaro driveshafts  were 49.56 inches long but yokes were different based on application.
Quote from: 69z28rsbilly on August 05, 2011, 01:38:29 PM
Tough to tell from the picture.  Can you tell us stripe colors?
Also do you have a measurement from center of u joint to center of u joint?
Quote from: erikjohn on August 05, 2011, 03:46:01 PM
1967
L-48
M-20
Los Angeles
Build Nov 66
U-bolts
Clocked @ 30deg
