date code help
Started by PPM, July 02, 2011, 07:20:02 AM
PPM
I have a 67 camaro with an 11b which is secondd week of november would that be nov of 66 or 67? also it is a los built car an on the trim tag after los it has a 6082 is this a sequence number and should it somewhat match the last four of vin which is 6219?   thank you
tmodel66
That would be November '66. The build number 6082 was just a body sequence number and will not match the VIN.
Daniel
PPM
Does 6082 or 6219 mean it was the 3082 or 3219th car built?
#3
Quote from: PPM on July 02, 2011, 08:49:35 AM
The 6082 after LOS means it was the 6,082nd '67 body built at Van Nuys.
Edit: Oops - forgot about the '67 LOS body numbering by style format.
Petes L48
Didn't the early 67 LOS cars have the four body numbers sequences running consecutively, depending on coupe or vert and then std or deluxe interior?  So it would be the 6082 of its particular group (coupe std or coupe deluxe since both verts types only got up to around 2000) thread?
http://www.camaros.org/bodynumbering.shtml
IZRSSS
Were the 69 LOS cars the only ones with the day of the week & # down the assembly line code isolated on the tag?
QuoteDidn't the early 67 LOS cars have the four body numbers sequences running consecutively, depending on coupe or vert and then std or deluxe interior?  So it would be the 6082 of its particular group (coupe std or coupe deluxe since both verts types only got up to around 2000) thread?
Yes, and since his car is a Coupe with Custom interior, it was the 6082nd car built with this combination.
QuoteWere the 69 LOS cars the only ones with the day of the week & # down the assembly line code isolated on the tag?
LA only, yes. Norwood didn't use the scheduling code, but no for "just 69". LA used this code for all three years. Read THIS for more info.
IZRSSS
PPM
thanks for all your help
