1969 z28 trunk cardboard seperator
Started by canadair, May 14, 2011, 07:07:59 AM
canadair
does anyone know if the rear trunk cardboard seperator behind the back seat if 2 differant ones where used mine is the original and looking from the trunk it has slots  cut in it allowing the view of the inners of the back seat springs, I looked at new ones and none have the slots
rat pack
New ones are made to fit all three years as 67's don't have them. You will have to cut the slots into the new one for your 69...........RatPack.............
IZRSSS
Can someone post a pick of what the cut out slots should look like?
joesauer
The slots are part of the ventilation/air circulation system.  Not sure about all years, but in 68, interior air vents through these, on into the trunk, and out the door pillar outlet grill.  68 Service Manual, Fig 5-1.
LM69Z28
I have photos available of my 69Z's insert but are unable top post them due to size?
email direct to mjk302@eartjhlink.net and am happy to send the photos.
Regards
Michael kellogg
LM69Z28 ;D
IZRSSS
Thanks for the infor Joe.
Michael thanks...PM sent
IZRSSS
James,
Thanks for the pics. Do you have any from the trunk side?
Thanks!
I do not have one of the whole divider from the Trunk side. It is a black color, almost looks as though the trunk side was dyed with an asphalt solution.
IZRSSS
Amazing...I don't know too many judges from my neck of the woods that know this is the case.
I just put a repro one in the 69 Z I am restoring now, the trunk side is black... or close to black, however it is not the same as the original one. It is WAY too finished looking. (the repro)
Mark
Those cutouts don't exist on early 68's.  Theres a dealer technical service bulletin 68-T-22 dated 1/28/68 that addresses the addition of these cutouts to "some early 68 Camaros.  Would assume that means they were suppossed to be there at the start of production but maybe some leftover 67 parts got installed in the early 68s/
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
IZRSSS
The bulletin refers to early '68's. Were these same holes already present for the '69 model year?
QuoteWere these same holes already present for the '69 model year?
Yes. Only early 68's had the issue.
