1969 z28 starter
Started by wisemanz28, April 24, 2011, 12:20:53 PM
wisemanz28
Is a 1969 Z28 starter supposed to have a cast iron nose or a aluminum nose?
Does anyone has a pic of one , I bought one from a guy and it won't bolt up to my Z28 for some reason.
1108367 with an aluminum nose.
Stingr69
You may have the wrong starter OR the wrong bellhousing-clutch-flywheel setup. The bolt holes are supposed to be in line, not staggered. Aluminum nose is typical. The number stamped on the steel starter case does not need to match anything.
What starter did you pull out of there before? What are the last 3 digits cast into the bellhousing? "403"? or "621"? or something else?
-Mark.
wisemanz28
Got it figured out guys , wrong flywheel
